Does the FAA have any regulations governing the design of a turbine engine FCU? I'm being questioned about an older Beechcraft PT6A FCU - in particular, how can I guarantee that when the power condition lever is at the shutoff/cutoff position, no fuel is moving to the combustor...? Any help would be appreciated... Thanks!
Edit - for those needing clarification:
Simply as stated, does the FAA regulate how a turbine engine FCU can be designed - pressure allowances, flow volumes, etc.
As stated, I'm being asked to prove that when the power condition lever in the cockpit is moved to the shutoff/cutoff (pick one term) position, fuel will not flow into the combustor. Tying into my first question, does the FAA regulate that a turbine FCU MUST absolutely cut off all fuel moving to the combustor, or is that just left to the designer to ensure...?
Hope that clarifies everything. Not sure how much more detailed I can get without specific and possibly pointed questions.
