In a recent Buzzfeed article about aerial surveillance, I have seen a map showing perfectly circular flight patterns. Given how precise the patterns are, I highly doubt that the aircraft were being hand-flown.
According to the article, the planes used for this kind of survey work are GA (among others, Cessna and Pilatus PC-12 are mentioned in the article).
I was wondering how would you get to fly such a pattern using a GA-grade autopilot?
I did some research and so far the only way I could find was selecting a circular pattern in a G1000 equipped with the "Search and Rescue" additional SD card. However in this case it seems you can only have a circle where the centre of the circumference corresponds to a known waypoint (See third last page in this PDF manual), so probably that method doesn't offer enough flexibility for the purpose of aerial surveillance (e.g. what if there are no waypoints over the area you need to survey?).
Another way I imagine you could achieve something similar to a perfect circle could be by carefully setting aileron/rudder trim I guess, but I doubt you could hold a stable pattern over time just by using trim controls, due to wind, turbulence etc.
Does anyone have more insight on how you could achieve a perfectly circular flight pattern while being able to arbitrarily place the centre of the circle in any geographical location?
    $\begingroup$ You can save waypoints based on coordinates. $\endgroup$
    – fooot
    Feb 25, 2018 at 5:16
    $\begingroup$ @fooot I think your comment pretty much answers my question, if you post it as an answer I will accept it. Thank you! $\endgroup$
    – mastazi
    Feb 25, 2018 at 6:25
Custom waypoints would work, but it would not be a smooth circle. And as far as I know looping the set of waypoints is not straight forward. Another way is the CWS (control wheel steering) function of some autopilots such as the King KFC 225 to hold a bank angle and to control the radius with the speed, but as you pointed out in a comment, it would not be perfect due to the wind.
Also a unit such as the Garmin 650/750 available for FAR 23 (small aircraft) has the new radius-to-fix and orbit functions:
  • $\begingroup$ You said: "Custom waypoints would work, but it would not be a smooth circle"; could you explain why that is the case? So if I create an Orbit SAR pattern around a custom waypoint, it's not going to be as smooth as if the Orbit SAR pattern was created around a waypoint taken from the aeronautical charts? $\endgroup$
    – mastazi
    Feb 26, 2018 at 1:49
  • $\begingroup$ @mastazi - custom waypoints as in drawing a circle by linking multiple waypoints on its circumference, like a polygon. $\endgroup$
    – user14897
    Feb 26, 2018 at 8:09
  • $\begingroup$ Oh I see, yeah that wouldn't be a good idea and I agree with you that it wouldn't be a smooth circle. I am accepting your answer, thank you for your help! $\endgroup$
    – mastazi
    Feb 26, 2018 at 12:27
  • $\begingroup$ Any idea what the smallest radius is? and/or what the increments are? 0.1 or 0.5? $\endgroup$
    – Biaspoint
    May 18, 2023 at 12:33
