In a response to a You-tube clip showcasing Piper's M600 single turbo prop, a viewer dismissed it as an inferior engine compared to a GE (probably an H-80 series) due to lack of FADEC or Electronic Engine Control (ECC) which GE engine has but lacking in PT-6.
Since controlling the PT-6 on the above aircraft does not seem to require a big workload from the pilot, I am wondering is there any necessity to equip this engine with FADEC, and whether the cost/benefit ratio is justifiable?
  • $\begingroup$ AFAIK FADEC is just a throttle limiter to an engine. Its a computer that sees all inputs from the engine sensors and limits the thrust accordingly. $\endgroup$ Feb 19 '18 at 16:42
  • $\begingroup$ @MarceloPacheco: FADEC controls fuel flow, but also the engine components themselves, to optimize flows, pressures and temperatures, and prevent compressor stall, using blade/vanes adjustments, valves and tip clearance mechanisms. $\endgroup$
    – mins
    Feb 20 '18 at 8:05
It is quite feasible and available on other PT-6 family engines. The PT-6C engine is available with FADEC but appears to be more for rotorcraft. That being said its fundamentally a similar engine and the systems could be migrated to the common PT-6A.
The question of:
This is somewhat of an opinion based question depending on what you personally feel is necessary. FADEC allows a pilot to run an engine at optimal performance all the time without needing to babysit the various engine parameters and settings. Some see this as a great benefit (taking something off your plate in a demanding airplane) while the more classically minded prefer to have finer control and operate their engines in various ways that may be considered less than optimal but appropriate for the mission.
The cost of FADEC is putting the engine control in the hands of a computer, which many are slowly becoming comfortable with. One thing to consider on smaller planes like the M600 is backup power systems. Large planes have the luxury of things like an APU and a RAT as well as lots of alternators and battery banks to mitigate power failures across 4 discrete power sources. The M600 has only its alternator and batteries as a backup so in the event of a power loss you have less to fall back on and may lose the engine.
Without knowing P&W's financials its hard to say. They are clearly selling lots of PT-6's and many might say theres no reason to change something that works. Since they clearly have a FADEC system for the PT-6C I would imagine a great deal of the work has been done and the system could be migrated to the PT-6A at least in part but you would need someone from PW to confirm that assumption.
Just a bit of a history note the PT-6A is a fairly old engine and has been around since the early 70's a time long before FADEC was small enough for something like the M600. On the same note the PA-46 first flew in '79 a bit before FADEC was viable on a small scale. There is some reality to keeping up a certified config once its certified.
This site is temporarily in read only mode and not accepting new answers.
