When on ground with APU bleed on and both engines off I have noticed a number of times that the pack flow isn't at the HIGH setting why?
As per the FCOM it states that when APU bleed is on the PACK FLOW automatically goes to the HIGH position regardless of the PACK FLOW selector position. But a number of times I have noticed on the BLEED SD it doesn't indicate HI even though both PACKS are on why? Is there any reason for this or some system particularly I don't understand?
