What is the shape of this power required curve for a small GA airplane, and for a large commercial airplane?
The answer depends on the span loading and flight altitude of the aircraft. For most practical cases, the left hand side power curve is more realistic, but it still can be entered if the pilot is unaware of what he/she is doing. Just witness AF447 …
The power curve is the sum of two drag curves, times flight speed:
- The induced drag is dominant at low speed and decreases with increasing dynamic pressure, and
- the friction (and parasitic and interference) drag grows with increasing dynamic pressure.
Below I have plotted the theoretical power curves for a small GA airplane at sea level. The dashed lines show the power curve if no flow separation would happen.
Aircraft with low span loading will exhibit low induced drag, so the friction drag (zero lift component) will become dominant soon. The higher the airplane flies, the more the available power is reduced and the induced drag is increased, so the power curve will shift to something resembling your right plot. The point splitting the left side of the curve from the right side is the point of minimum power. Where is this point for actual configurations?
We can calculate the lift coefficient at minimum power in order to know where the speed range of the backside of the curve starts. In this answer, I derived this already, so here is only the result:
$$c_{L_{min.\:power}} = \sqrt{\frac{2-n_v}{n_v+2}\cdot c_{D0}\cdot\pi\cdot AR\cdot\epsilon}$$
The symbols are:
$\kern{5mm} c_L \:\:\:$ lift coefficient
$\kern{5mm} n_v \:\:\:$ thrust exponent, as in $T = T_0\cdot v^{n_v} $
$\kern{5mm} c_{D0} \:$ zero-lift drag coefficient
$\kern{5mm} \pi \:\:\:\:\:$ 3.14159$\dots$
$\kern{5mm} AR \:\:$ aspect ratio of the wing
$\kern{5mm} \epsilon \:\:\:\:\:\:$ the wing's Oswald factor, normally between 0.8 and 1.0
Now let's input the values for a glider ($n_v$ = -1):
$$c_{L_{min.\:power}} = \sqrt{3\cdot 0.00935\cdot\pi\cdot 21.43\cdot 0.98} = 1.36$$
So the minimum power speed for the ASW-20A is very close to its stall speed. Falling into the backside is practically equivalent with stalling.
Now the values for a jet fighter ($n_v$ = 0):
$$c_{L_{min.\:power}} = \sqrt{0.0172\cdot\pi\cdot 2.45\cdot 0.76} = 0.317$$
So the Starfighter pilot is on the backside of the curve until he accelerates beyond 191 m/s or 371 knots (at maximum take-off mass). That is already Mach 0.54 at sea level (and more the higher you go), and explains why the Starfighter prefers to be flown fast. Its best climb speed is at Mach 0.9!
Since you asked about a commercial airplane, here we go:
$$c_{L_{min.\:power}} = \sqrt{1.67\cdot 0.01277\cdot\pi\cdot 9.58\cdot 0.74} = 0.687$$
This is for the clean configuration of course and falls between the glider and fighter values. The numbers for a GA aircraft are a little higher (around $c_L$ = 1) due to the piston engine, with a higher Oswald factor due to an unswept wing and a somewhat lower aspect ratio. Commercial aircraft prefer to cruise close to the minimum drag point, which for this example is at $c_{L_{min.\:L/D}}$ = 0.532, so at altitude their operating point is already quite close to the backside range. In contrast to that, a GA aircraft in cruise will fly low (no pressurisation) and much faster that at its minimum power, so its cruise point will be far to the right of the backside range, making the power curve look more like your left hand side example.
