13
When departing form Osaka International (KIX) the Osaka city passed below twice, the second time much lower. Looks like our 747-400 was circling up in spiral before heading a long way over Russia to Europe.
I understand the reason of flying in circles before landing (holding pattern, waiting in a queue for landing). But why circle over the airport of departure? I think it could be more economical and faster to pick the altitude while heading in a needed direction. Is there also a queue to leave the airport? Why not to wait on the ground then?
If was the flight LH741 (Osaka - Frankfurt), departing 24.10.2017, 10:00 from Terminal 1.
    $\begingroup$ Have a look at the airport charts: Some SIDs (Standard Instrument Departure) mandate circling. $\endgroup$
    – DeepSpace
    Feb 9, 2018 at 20:46
    $\begingroup$ Sometimes circling patterns are flown while climbing after departure in order to gain altitude before setting course across terrain or restricted airspace (although probably much more often for terrain). $\endgroup$ Feb 9, 2018 at 21:07
  • $\begingroup$ Related, maybe a dupe? It's a different airport, but the same basic question. $\endgroup$
    – Pondlife
    Feb 9, 2018 at 23:01
21
Looking at FlightAware, we see this takeoff for your flight:
Examining some airport charts for KIX, this looks like the standard departure NANKO REVERSAL THREE DEPARTURE from runway 06R.
I guess that the loop is to give the aircraft enough time to climb to 8000 before it reaches NANKO. And, I guess the 8000 feet is for either terrain or noise abatement (notice the climbing loop is entirely over water.)
    $\begingroup$ The crossing restriction may be also to separate traffic from the other Osaka International Airport, RJOO/ITM, which is almost in the way. $\endgroup$
    Feb 14, 2018 at 20:54
  • $\begingroup$ There's also Kobe Airport (RJBE) visible in the last chart as an island on the north end of the bay. $\endgroup$
    – Jeff B
    Feb 15, 2018 at 5:29
13
+50
NANKO ONE Departure
The NANKO ONE Departure, as already written by Robᵩ, is one of the most used departures out of KIX/RJBB.
The unusual design with the climbing pattern over the bay is used to minimize interference with the traffic in and out ITM/RJOO Osaka International Airport also known as Itami Airport in the north of the city and to reduce noise over populated areas. But let me explain in detail:
Geographic situation and airports
Map of Osaka greater area showing the four airports Screenshot from https://skyvector.com
The Osaka Bay area is densely populated and served by numerous airports, airfields and helipads. For your question we concentrate on the following four airports:
The area has two large airports:
  1. KIX/RJBB Kansai International Airport
    • 177,109 aircraft movements (2016)
    • ~25.3 million passengers (2016)
  2. ITM/RJOO Osaka International Airport aka Itami Airport
    • 139,630 aircraft movements (2015)
    • ~14.6 million passengers (2015)
and two smaller ones:
  1. UKB/RJBE Kobe Airport
    • 27,468 aircraft movements (2015)
    • ~2.4 million passengers (2015)
  2. none/RJOY Yao Airport
    • airbase for the Japan Ground Self-Defense Force
    • also used by general aviation
    • no numbers published
Runway layout and ATC considerations
You might have noticed that the runway systems of KIX and ITM are perpendicular to one another. Kobe and Yao have runways parallel to each other but at a 45 degree angle to KIX and ITM. This poses a problem with arriving and departing traffic to all four airports.
Westerly wind direction
Think of wind from westerly directions. In this case ITM uses RWY32L/R und KIX uses RWY24L/R. Normally you line up the arriving traffic on the runway centerline about 15-20NM out. Keeping this in mind the arriving aircraft will cross their path somewhere in the east of Osaka. Additionally UKB will use RWY27 and their arriving traffic is crossing the path of the two others as well. Add Yao (RJOY) departures on RWY27 into the mix and you have a nightmare ATC-wise sorting and spacing the traffic to avoid separation conflicts. This reduces the capacity of all involved airports as the spacing between arriving flights has to be bigger to accommodate for arriving (and departing) flights of the other airports.
Easterly wind direction
Now to your case - departures with easterly winds. In these conditions KIX uses RWY06L/R as you did on your flight. ITM will use RWY14L/R. If both airports used straight out departures you have a crossing situation similar to the arrivals with westerly winds. Add Kobe (UKB) using RWY09 to the mix and you have three departure routes crossing. To add some flavor for the controller there might be an arrival into Yao (RJOY) RWY 09. Another ATC nightmare.
Noise
The described situations above are all based on hypothetic straight out departures and arrivals. You surely know that, as a rule of thumb, an aircraft makes more noise the higher the flap setting. Departures and arrivals over populated areas introduce a lot of unwanted noise into local communities. This is therefore something to be avoided.
Sophisticated airspace layout
A solution to most of the problems described above lies in the unusual airspace and departure/arrival procedure design. Lets have a look at the KIX arrivals first:
Approaches into KIX Cropped from the Japanese AIP RJBB AD2.17 Positive Control Area
The image shows the final approach for both directions. RWY06L/R is rather straight forward. From TOMOH straight on the centerline all the way down to the runway. RWY14L/R is a different beast. At MAYAH you are far from aligned with the runway centerline. You are basically flying in the wrong direction. But it avoids Kobe (UKB) neatly and stays clear from the ITM area further north-east. Additionally it keeps the noisy aircraft (flaps and gear extended) over the water.
Airspace in the Osaka Terminal Area Cropped from the Japanese AIP RJBB AD2.17 Terminal Control Area and colored by me.
I highlighted the relevant KIX airspace in blue and the ITM airspace in green. You can imagine the "funnels" to guide the traffic in and out of the airports. This way you have the traffic for both airports separated.
But whats about departures to the north-east like your Lufthansa flight? You need to cross the path of the traffic of the other airport somewhere. Here, the magic sauce is vertical separation. Just keep one traffic flow way higher than the other and you avoid the need to separate them from each other manually. The straight line distance from the runway in KIX to NANKO is too short to reach the required altitude to stay clear of the other traffic. That is basically the reason for that "circle" you flew on departure.
NANKO ONE Departure Cropped from the Japanese AIP RJBB AD2.24-SID-19
It extends the mileage to NANKO so the aircraft can reach a higher altitude at that waypoint. Additionally the flap retraction is kept over the Osaka Bay, the aircraft crosses the shoreline at an higher altitude and noise over populated areas is minimized. Pretty clever in my eyes.
I hope this explains it in more depth - feel free to ask for clarification.
Cheers, Chris
The reason is to keep you over the water in the climb for noise abatement for the city. Japan is very noise sensitive. You climb to get higher over the water at high power settings before going over land. Hence you are at a higher altitude which equals less noise for the city.
