19
What is the rationale behind forcing passengers to check in dangerous items?
What makes liquids and gels more dangerous in the cabin? Why would a lithium ion battery be less dangerous as check-in luggage? Wouldn't that even be more dangerous when you put lots of batteries in the cabin, since one could catch fire and spread to all other batteries where passengers are?
32
Generally, "dangerous" things that might be used as weapons are required to be kept out of the cabin. For instance, you can have firearms in checked baggage, but not carried in the cabin.
Given what's been learned about terrorist planning, there were plots to bring liquids on board an aircraft that could be combined to form an explosive. To counter that threat, the amounts & types of liquids that can be brought on board have been limited. Since the liquids in isolation are safe, they're allowed in normal quantities in checked luggage.
In the case of Lithium Ion batteries, the concern is less their use as a weapon, and more about a defective battery catching fire. If this were to happen in a cargo hold, the fire would cause other things to start burning as well before the cargo smoke detectors alert the crew to what's going on. So the priority is to keep lithium ion batteries out of the cargo hold. They're allowed in the cabin (with some restrictions) since you're pretty likely to notice your cell phone getting hot & smoking if it's in your pocket, and with that sort of early notice, the fire can be dealt with before it's caught large volumes of material on fire as well.
At least that's the theory. I don't know how many times it's been put to the test. In at least two cases (the Samsung Note 7 phone, and hover boards), devices which are considered to be at high risk of catching fire are simply kept off the aircraft altogether.
    $\begingroup$ @Scott You have more faith in the TSA's rationality than I have. theatlantic.com/national/archive/2014/01/… schneier.com/essays/archives/2009/11/beyond_security_thea.html $\endgroup$
    – Charles
    Jan 29, 2018 at 2:46
    $\begingroup$ @Scott "liquids mixed by some Macguyvered mechanism would not be a threat" Presumably the idea is that scanning of hold-baggage would spot anything more suspicious than completely separate containers. $\endgroup$
    – TripeHound
    Jan 29, 2018 at 10:06
    $\begingroup$ @scott in the TSA's own words: tsa.gov/blog/2008/02/04/… (which doesn't really answer the question, though); a better explanation at science.howstuffworks.com/liquid-explosives.htm describes several combinations of relatively safe chemicals that can be mixed into an explosive. Fox News even describes how Tang drink mix and the hydrogen peroxide from your medicine cabinet can make a bomb. foxnews.com/story/2008/05/17/… $\endgroup$
    – arp
    Jan 29, 2018 at 11:10
    $\begingroup$ @Scott There are lots of liquids that, if mixed, are explosive or incendiary. A basic chemistry class should resolve any disbelief of that. As for the MacGyvered mechanism in hold baggage, hold baggage is x-ray screened and (at least in the U.S.) also tested for explosives, so the idea is that they'd catch that in screening and not let the bag on the plane. For carry-on baggage, someone could take their bag into a lav (or a first class suite, etc.) and combine the chemicals manually, so there would be no MacGyvered mechanism for security to detect. $\endgroup$
    – reirab
    Jan 29, 2018 at 15:54
    $\begingroup$ The term for the liquid mixable explosives is binary explosives. $\endgroup$
    – T.J.L.
    Jan 29, 2018 at 21:15
13
Why is the rationale of forcing passengers to check-in dangerous items?
To stop people using them as weapons to hijack the plane.
There was a terrorist plot in which suicide bombers would blow up planes using liquid explosives disguised as soft drinks. Of course, somebody could try to put such a bomb in checked luggage but that would require some sort of timer and detonator, which would likely be spotted when the luggage is X-rayed. So the specific concern is that a bomb could be assembled and detonated in the cabin using only innocent-looking liquids and other items.
Why would a li-ion battery be less dangerous as check-in luggage? Wouldn't that even be more dangerous when you put lots of batteries in the cabin, since one could catch fire and spread to all other batteries where passengers are?
Lithium batteries are more dangerous in check-in luggage.
How would the fire spread between batteries in the passenger compartment, unless the whole cabin is on fire? Your laptop isn't suddenly going to start burning just because my cell phone has caught fire in the seat next to you.
If a battery fire starts in the cabin, somebody will notice before it sets much else on fire. They can then put the fire out. The standard technique, I believe, is to drop it in a bucket of water, which removes all the heat from the system, as well as starving it of oxygen. Everybody lives to tell the tale.
In contrast, if a battery fire starts in the cargo hold, it's in an area that's densely packed with flammable things such as clothing. That means that, by the time the fire is detected, it is probably quite big. Further, the only way to fight such a fire is with a general fire suppression system that tries to starve the entire hold of oxygen. That doesn't remove the heat so, even if it puts the fire out, it's possible that the still overheated battery will reignite the fire. This is an extremely dangerous situation that could well kill everybody.
    $\begingroup$ @QuoraFeans Probably not for a laptop. But for phones, I think that's the procedure. $\endgroup$ Jan 28, 2018 at 21:32
    $\begingroup$ @QuoraFeans -- Li-Ions always are suppressed using water to quench the runaway reaction. Class D agents can be actively harmful due to the fact that a burning Li-Ion battery has oxygenated fuels and decomposing cathode oxide (producing oxygen) in it already, so it doesn't need all that much air to burn or propagate the runaway to adjacent cells. $\endgroup$ Jan 28, 2018 at 23:50
    $\begingroup$ Regarding lithium-based batteries, Why is there so much fear surrounding LiPo batteries? on Electrical Engineering may be of interest. $\endgroup$
    – user
    Jan 29, 2018 at 9:05
    $\begingroup$ @reirab So you have a choice between "releases toxic fumes and stays nicely contained in a water bucket" or "releases toxic fumes and also catches everything else on fire". Pick one $\endgroup$
    – user253751
    Jan 29, 2018 at 22:00
    $\begingroup$ @reirab, lithium doesn't explode when mixed with water. Lithium produces hydrogen and heat when mixed with water, and it's the hot hydrogen that explodes. Drop your lithium in enough water, and you get cold hydrogen that never builds up to explosive levels. $\endgroup$
    – Mark
    Jan 30, 2018 at 1:13
