Mode A selected on the transponder provides identification of the aircraft to the secondary radar; Mode C will add an automatic height read-out of an aircraft. Mode S is a selective addressing. But previously there was a Mode B which nowadays is not in used anymore. What was it used for, and what information was this mode able to provide?
Mode B
SSR modes B and D are not used today, but mode B has been used in UK, Australia and some other countries for some time, and it was compliant with mode A:
In reply to interrogation in Mode-A and Mode-B information of identity, which is set by the pilot, is sent to the ground interrogator.
Source: Radar Theory for Area/Approach Radar Controllers
Modes A and B are used with a squawk code of 12 bits, offering 4096 different identifiers. In both modes the code is selected on the SSR transponder panel, using 4 octal digits (0 to 7).
SSR transponder panel, source
For a transponder handling multiple modes, the correct mode must be selected in parallel of the squawk code.
The interrogator (SSR ground station) can request identifiers using one mode at a time, and receive answers from transponders set to that mode. Aircraft using code 1234 will only reply when interrogated using the mode their are currently set to.
All legacy modes, military and civil and mode S
SSR interrogation modes are identified by the timing between pulse P1 and P3 (P2 is used to reject interrogations from secondary SSR lobes).
SSR modes identification, adapted from source
While mode A is compliant with military mode 3 (both often referred to as 3/A), mode B is purely civil. Its purpose is assumed to be an extension of the mode A, giving 4096 additional codes to ATC.
ICAO Doc 9684 which is the reference for SSR doesn't even mention modes B and D anymore.
Mode S specificities
To be exhaustive, let's mention Mode S visible at the bottom of the previous image.
Mode S (for select) allows to interrogate transponders one at a time when necessary, to prevent FRUIT. In addition of the squawk code, mode S transponders are given by authorities a unique (and quasi-permanent) 24-bit address. This address is used by SSR interrogators to specify which transponder is the recipient of the interrogation.
The address is sent in a datablock which modulation is not a pulse like P1 and P2, but a burst of carrier which phase is reverted when bit is 1 (see a detailed explanation in section Mode S of this answer).
This burst is led by a synchronization of phase reversal (SPR) burst, at the timing of legacy pulse P6, which role is to prepare the receiver to detect possible phase reversals events, hence to decode bits at the right time. In other words this is a clock synchronization. The data themselves can be a series of 56 bit when only the address is required, or 112 bits when the "interrogation" carries an ADS-B message too (with this message, we are entering a data link mode, this is where the ATC future lives).
$\begingroup$ Good info on the interrogation, but how is the reply code entered and coded? An additional 4096 codes would require just a single bit. Was it an A/B or 0/1? Where was the extra bit in the reply? $\endgroup$– GerryJan 29, 2018 at 0:54
$\begingroup$ @Gerry: I believe the code would be entered like mode A/C (no additional digit), a selector would be switched to B on the transponder panel. There is no need for a 13rd pulse in the reply, ATC would know what to do with the code, knowing they interrogated in mode B. I read the L-1101 had such transponder with modes A and B, when flying in related areas. $\endgroup$– minsJan 29, 2018 at 1:14
5$\begingroup$ That makes sense. So a pilot is told to "squawk Mode A, 4523" and another can get "squawk Mode B, 4523" and the ATC computers can track them without ambiguity as they are interrogated separately. $\endgroup$– GerryJan 29, 2018 at 1:52
Mode B is also used as an antenna test pattern measurement within the FAA MSSR type systems. The MSSR interrogates a dual transponder test set with a mode B, which initiates the test pattern. This is used for troubleshooting and antenna health checks. Mode D is selectable as well, but currently not utilized.
$\begingroup$ "Mode B is also used as an antenna test pattern measurement" there is no need to use any information to establish the radiation pattern of an antenna, therefore it would be useful to provide a link to the documentation confirming the use of mode B by FAA, that would allow to understand the exact purpose. "Mode D is selectable" by who? how? $\endgroup$– minsAug 2, 2021 at 14:17
