What kind of communication do the intercepting and intercepted aircraft use? Is it the usual air-to-air frequency or the international emergency frequency?
$\begingroup$ I think you might need to expand this a little bit. What sort of interception are you talking about? In what jurisdiction? And why do you think this is specific to VFR? $\endgroup$ – Jamiec♦ Jan 25 '18 at 12:58
An interception with an aircraft that's either on an unknown frequency, or non-responsive etc will be conducted on the emergency frequency of 121.5. Likewise, a pilot would be expected to tune into that frequency if they found themselves the subject of an interception.
There is no other standard "air to air" frequency that's likely to be utilised. I'm aware that some countries have special frequencies reserved for formation flight etc, but most pilots wouldn't have those memorised and wouldn't be expected to use them.
However, if the aircraft is/was communicating on a known frequency then there'd be no reason that an interceptor couldn't use that.
