I need to measure the angular variation of a helicopter. Hence, I am looking for a 3-axis gyroscope? However, what kind of specification the gyroscope should have, like sample rate etc? Therefore, I want to know how the angular velocity changes (in any axis) in helicopter. I need to know the range only.
Any reference would be highly appreciated.
  • $\begingroup$ Angular displacement due to flight manoeuvres? $\endgroup$
    – Koyovis
    Commented Jan 24, 2018 at 0:22
  • $\begingroup$ @Koyovis yes, in addition while moving in land in wheels etc. $\endgroup$
    – Creator
    Commented Jan 24, 2018 at 0:32
3-DoF magnetic gyroscopes are a dime a dozen nowadays, together with 3-DoF accelerometers, magnetic field sensors, and GPS position transducers. These are in mobile phones now, tiny and frugal with electricity. A google search for "9-dof position acceleration gyroscope" results in a lot of options.
For the sampling rate: this needs to be at least twice the frequency of the fastest vibration - more is better, since a frequency at half the sampling rate shows up as a triangular wave.
from the linked site
For the frequency range of angular displacement, this article might be of interest. It shows vibration data of a car driving over the road, using an iPhone to measure the vibrations. The article mentions a sprung frequency (inside the vehicle) of 1 - 5 Hz. A helicopter usually has higher inertia than a car, so sprung frequency should be lower. If you take 0 - 10 Hz as a baseline for the range, you should be safe. The ground reaction angular frequency range is always higher than the airborne one: responses in the hover are measured in seconds, not in Hz.
Above graph shows pitch response of an example helicopter, from Prouty, Helicopter Performance, Stability and Control. A helicopter with a rotor mounted on top is unstable in the hover, but in order to still be controllable for human pilots the response frequency may not be too high - it turns out that humans can comfortably control instabilities with a time period in the order of around 10 sec. The military have requirements for the stability response in MIL-H-8501A
  • $\begingroup$ "The ground reaction angular frequency range is always higher than the airborne one." Is there any reference or insight to it? This is the most important insights I was looking for. $\endgroup$
    – Creator
    Commented Jan 24, 2018 at 1:52
  • $\begingroup$ Yes you're right, that is a bit of a sweeping statement. Have expanded the answer. $\endgroup$
    – Koyovis
    Commented Jan 24, 2018 at 2:50
