Is it possible to build a jet engine that utilises excess heat for thrust or does not produce any excess heat hence no need for cooling which is wasted energy
    $\begingroup$ You cannae change the laws of physics. $\endgroup$
    – GdD
    Commented Jan 11, 2018 at 13:23
10
No, any thermal machine always transfers energy from the heater to the cooler (Carnot cycle). The maximal yield depends on the temperature difference and cannot achieve exactly 100%. It is equal
$$ 1-\frac{T_\text{C}}{T_\text{H}} $$
where Tc is the temperature of the surrounding air and Th is the temperature of the burning fuel. Jet engine as normally understood in aviation is a thermal machine.
