I was thinking about a simple super-light aircraft powered with a little low-power piston engine. Is there any way that we can design a wing so the aircraft flies very slow (like 25 km/h as minimum speed) without stalling? I mean a suitable wing design for this kind of aircraft. (slow one) Other questions:
  • Which parameters in designing wings must be considered for lowering stall speed?
  • My thrust power is low so I accept lower cruise speeds.whats the effects of this on my design?
  • Can we choose thicker airfoils for wing and ignore the drag issues due to low speed?
  • $\begingroup$ Basically you’re going to need a lighter weight or higher aspect ratio wings, or both (sounds like a glider, huh?). $\endgroup$
    – Pugz
    Jan 10, 2018 at 16:55
    $\begingroup$ Any wing can have any arbitrarily low stall speed - if you ask it to generate (or support) a low enough load (weight). SO the answer is related to the Power-to-weight ratio. Look at human-powered flight aircraft for examples: en.wikipedia.org/wiki/Human-powered_aircraft & en.wikipedia.org/wiki/Power-to-weight_ratio $\endgroup$ Jan 10, 2018 at 17:14
  • $\begingroup$ More than Power-to-weight ratio, I'd say key factor here is wing loading. $\endgroup$
    – qq jkztd
    Jan 10, 2018 at 17:50
  • $\begingroup$ (by "more than" I mean : every aircraft has to glide in the first place. balancing dead weight will be replaced by engine-propeller afterwards) $\endgroup$
    – qq jkztd
    Jan 10, 2018 at 18:17
  • $\begingroup$ It sounds like you're describing a motor glider $\endgroup$
    – TomMcW
    Jan 10, 2018 at 18:18
The first thing you need is a large wingspan $b$. This will help to spread the lift over more air and reduce induced drag, which grows inversely with the square of flight speed $v$: $$D_i \propto \frac{1}{v^2} \text{ and } D_i \propto \frac{1}{b^2}$$
Large wings have a high root bending moment, which requires a strong and heavy structure. Next you should add bracing, at least on the lower side of the wing. For that to be effective, you need a high fuselage so the bracing will become efficient. Yes, those wires will add drag, but at low speed this will be a lot less than the added lift-induced drag from lifting a heavier structure.
Dedalus human powered aircraft
The single bracing wire can hardly be seen on this picture of the Dedalus human powered aircraft, but it is there and saves a lot of drag at low speed (picture source)
Next, pick the right airfoils. Depending on the local Reynolds number, use thin and highly cambered ones but make sure that the pressure rise on the rear upper surface is slow enough to prevent early separation. One example is the DAE31 outer wing airfoil of the Dedalus aircraft (the inner and mid-span ones are DAE11 and DAE21). At Reynolds numbers of 500,000 to one million, turbulators positioned 2-3% ahead of the separation line will trip the flow and make the airfoil tolerate steeper pressure gradients.
Pick wing chord such that the wing area gives a lift coefficient around 1, details depending on the exact Reynolds number. Lower values go with lower Reynolds numbers.
Wings that would produce sufficient lift at that low of a speed would have an enormously high induced drag. So unless you are operating a model plane that weighs almost nothing - I don't think you will have any luck.
In theory...
You would need a high cambered wing to produce lift at low speed. The wing should have a very smooth surface and max camber should be placed further back to promote laminar flow which reduces air resistance. You could also use turbulators at the seperation point. Basically anything that helps to reduce weight and drag is your friend.
To reduce the risk of a stall you should also look at slotted flaps so that a higher angle of attack is possible.
To achieve a low Induced drag you should have an elliptical wing shape and a very high aspect ratio with winglets.
Such wing could be designed without much of a problem. Your plane could however not fly without an extremely powerful motor to counter the insane induced drag. Such motor would then weigh a lot. So you would need even more lift resulting in more drag thus an even more powerful motor and so on and so forth.
Therefore just use a helicopter ;) The slowest glider I have ever flown had a stall speed of around 60 km/h and it was an extremely light wooden aircraft. I am sure you could get a little better than that with todays technologies. But there is a reason why todays sailplanes fly faster rather than slower than they did 60 years ago.
