After having encountered this meme too often for comfort, I ask myself today in order to have the possibility to explain the issue in detail.
$\begingroup$ Where is the meme? $\endgroup$– David DeVineMar 30, 2018 at 22:34
$\begingroup$ @DavidDeVine: That static longitudinal stability would require download on the tail, as the question says. $\endgroup$– Peter KämpfMar 30, 2018 at 22:51
No, static longitudinal stability does not necessarily imply a download on the tail.
Static longitudinal stability requires that the Centre of Gravity is in front of the Centre of Lift, indicated as n.p.$_{fixed}$ in the drawing. Only then will an increase in Angle of Attack d$\alpha$ result in an opposing pitching moment: if d$\alpha$ > 0 then $dC_N$ > 0, resulting in a higher lift force. The neutral point must be behind the CoG in order to transform the higher lift into a nose down moment. Note that the drawing shows a longitudinally stable situation with a positive lift on the horizontal tail.
$\begingroup$ +1 Yes, Might I add, that it is this simple. "Static longitudinal stability requires that the Centre of Gravity is in front of the Centre of Lift". It can be the case that this can happen with two airfoils generating positive, (upwards) lift, one in front of the CG, producing a nose up pitch moment, and one behind the CG producing nose down pitch moment, (and this is the case for a canard-design), but in conventional (elevator at tail) aircraft, this is not the normal condition. $\endgroup$ Jan 9, 2018 at 16:04
$\begingroup$ Why? I believe ACs are determined using the same math as are CGs. Imagine x is the Wing Lift Moment arm, and y is the Tail(elevator) lift moment arm. W is wing lift and T is tail Lift. Then for the overall Aerodynamic center (AC) or Center of Lift, to be behind the CG, Ty must be greater than Wx. Ty > Wx <=> T/W > x/y. The Tail lift to Wing Lift ratio must exceed the Wing Moment arm to Tail moment arm ratio. True in a canard, where T is always > than W. Possible in a conventional aircraft (x very small, or a large T), but this would not be normal design. $\endgroup$ Jan 9, 2018 at 16:32
1$\begingroup$ It's a bit questionable if you ask me, it depends on your definition of stable. The answer is completely correct, both configurations can be stable during normal operation, only when you have a download on the stabilizer, it is also stable when the flow around the stabilizer is disturbed at very high angles of attack. Configurations with upward stabilizer force will almost certainly crash in that case. $\endgroup$– OrbitJan 11, 2018 at 14:30
$\begingroup$ @rickboender Yes indeed! In calm and well defined conditions a positive tail load can be statically stable. However the neutral lift point has a nasty tendency to shift forward in adverse circumstances, like when in a sideslip there is partial loss of lift of the tailplane. Only when the aircraft is trimmed with a negative tailplane load can stability be guaranteed in all circumstances. Definitely during start and landing at higher angles of attack. However, during fast cruise, does the tailplane ever experience a vertical gust strong enough to stall it? The velocity triangle says no. $\endgroup$– KoyovisJan 11, 2018 at 22:24
For the impatient reader: The answer is no.
Let me explain it in detail. For this, it is helpful to simplify things as much as possible and then add the complications step by step so I can explain what each changes.
The simplest layout uses a symmetric airfoil for both wing and tail and arranges both in the same plane and without a difference in incidence. If this arrangement is moved through the air at the subsonic speed $\text{v}_\infty$, the graphical representation in side view would look like this:
Both produce only friction drag and no lift. Now we add some angle of attack, in the next picture I chose 5°:
Now both create some lift (green arrows) in proportion to their size. The loading per area is the same for wing and tail - both have the same angle of attack and the same flow conditions, after all. Also, the local lift can bee summed up in the quarter point of the respective chord in both cases.
But that is too simple! Lift is created by deflecting air downwards, so the above picture is strictly possible only for wings of infinite aspect ratio. Therefore, the next picture shows the same arrangement with some downwash angle added behind the wing, so the angle of attack on the tail is reduced by $\alpha_{\text{d}}$ = 2° in this example:
This still leaves a positive local angle of attack on the tail (the downwash angle is quite a bit smaller than the wing's angle of attack, counted up from the zero-lift angle, for most regular airplanes), so the tail lift is still positive. In order to be trimmed at this angle of attack, the center of gravity needs to be between both lift vectors at a location proportional to the ratio between the two lift vectors.
But now a change in the angle of attack will change the local lift of both surfaces in proportion to the angle change. The result is an indifferent behavior towards changes in angle of attack. Flyable, but rather stressful. So we need to add a lower incidence at the tail in order to achieve static longitudinal stability:
Now the angle of attack on the tail is reduced by another 2°, and only a very small but still positive lift vector remains on the tail. The center of gravity needs to be shifted forward, very close to the quarter point of the wing to trim the aircraft.
A difference in the angle of incidences of only 2° is rather small, so we increase that to -5°, and now we indeed get a download on the tail:
If we now increase the angle of attack to 10° because we want to fly more slowly, we get more lift on the tail, right? The result should look like this:
With double the angle of attack on the wing the downwash angle doubles as well, but since the tail sees the same angle increase, its lift will turn positive, doesn't it?
Wrong again! The center of gravity has not changed, and in this configuration the tail has more lift than what is required for trimmed flight. And it better should - this is a stable configuration, after all, and an imbalance must result in order to create the nose-down moment required for stability.
A trimmed configuration needs to deflect the elevator to trim the new angle of attack. Since the lift on the main wing can be summed up in the same point in both angle of attack cases, the lift on the tail must be equal to the earlier trim case, like this:
This insight can be generalized: For airplanes with symmetric airfoils (like aerobatic airplanes) the lift force on the tail at trimmed level flight will be the same, regardless of speed. For that reason, a wing airfoil with a low travel of its center of pressure will require the smallest possible tail surface for a given wing surface in order to be trimmed at all speeds. This reasoning drove Willy Messerschmitt to pick the NACA 2R1 for most of his fighter designs and even the Me-321 cargo glider.
But for regular aircraft, a cambered airfoil is more common. Now we remove the last simplification and camber the wing airfoil. Below I adjusted the airfoil shape, but not it's incidence, so the now negative zero-lift angle will result in a larger effective difference in the angle of incidences. Whereas the zero-lift angle of the symmetric airfoil before was at zero degree, the cambered airfoil has a negative zero-lift angle of attack. Would the symmetric airfoil be mounted at the same effective angle of attack, its incidence would be higher. The tail incidence of -2° from case 4 can be reused here:
Now the downwash angle is higher, because the cambered wing produces more lift at the same geometric angle of attack, and the lift vector on the tail is negative again. The lift vector on the wing has shifted back due to camber (the lift vector of the symmetric airfoil is still plotted in light green), so the center of gravity is now ahead of the wing's center of pressure.
But in all the last cases the lift on the tail is negative, isn't it? Does that mean that the lift on the tail is negative in all cases?
No, it doesn't. Again we increase the angle of attack to 10°, but whereas the tail lift did not change when a symmetric airfoil was used on the wing, the cambered airfoil experiences a forward shift in the center of pressure when the angle of attack is increased. Consequently, even in the trimmed case now the tail lift will change to a positive value again!
Note that the elevator is again deflected in order to trim the new angle of attack. Even though, the lift has crossed into positive values again. Not much, but a high lift on the tail should be avoided anyway. Not only should sufficient margin remain for control inputs, but also because lift on the tail is more expensive in terms of drag.
Conclusion: A stable configuration can be achieved with positive lift on the tail, at least at high angle of attack.
This is due to the shift in center of lift? $\endgroup$– TomMcWJan 7, 2018 at 21:07 -
Now the downwash angle is higher and the lift vector on the tail is negative again.
Why is the downwash angle higher? $\endgroup$– TomMcWJan 7, 2018 at 21:07 -
$\begingroup$ @TomMcW: First question: No, but due to camber which means that the same geometric angle of attack produces a higher effective angle of attack (which is measured between the zero-lift angle and the geometric angle). Second question: At the same geometric angle of attack the cambered wing has more lift and, consequently, more downwash. $\endgroup$ Jan 7, 2018 at 21:17
$\begingroup$ Static stability: what is the direction of the pitching moment upon a change in angle of attack due to a gust, does the change in pitching moment counteract the change in AoA or does it tend to amplify it? That is clearly always the case when CoG is in front of centre of lift. I cannot see how the forward shift in lift of a cambered airfoil helps with a stabilising pitching moment. $\endgroup$– KoyovisJan 7, 2018 at 23:21
$\begingroup$ @Koyovis: The travel of the center of pressure of a positively cambered airfoil destabilizes the aircraft. But if the tail is big enough, overall stability is the same as with a symmetric airfoil and a smaller tail. $\endgroup$ Jan 8, 2018 at 10:09
In another answer it was stated:
"... Lift is created by deflecting air downwards, so the above picture is strictly possible only for wings of infinite aspect ratio. Therefore... "
I politely demur. Any airframe, no matter the aspect ratio of the wing (or tailplane), will generate positive lift on both surfaces if the angle of attack is increased to a sufficiently positive value. This does not imply that this configuration would be stable.
As to downwash, yes there is downwash, but the downwash at the tailplane is very dependent on the position of the tailplane relative to the wing. In some aircraft, where the tailplane is mounted high up (a T-tail) the downwash is significantly less than the downwash when placed in a lower position (although, because of obvious effects, the downwash effect inceases as AOA increases - in fact this is what caused the infamous "pitch-up" issue in the McDonnell Douglas F-101 Voodoo, because of it's T-tail, and is the main reason for the anhedral on the F-4 Phantom horizontal stabilator).
To assume that the change in AOA at the tailplane due to downwash from the wing is a standard, calculable value independent of wing AOA, speed, G-loading, or placement of the tailplane is not a valid assumption.
Next, the issue of static stability is not explicitly addressed. Discussing the scenario of two different stable situations both of which are at 1-G level flight, but just at different AOAs and speeds, does not address what would happen if AOA was increased at the same speed.
When we talk about static stability, a common mistake is often made. We discuss overall static stability, as qualitatively measured by the magnitude of the static margin (the distance between the OVERALL aerodynamic center and the CG), but then, in diagrams, we draw separate vectors displaying the Force on the wing and the force on the tailplane. The total aerodynamic center is the combined effect of all aerodynamic forces on the airframe from all surfaces, not just the wing. and because the tailplane is so much further from the CG than the wing. it's effect moves the AC further aft than the green vectors in Mr Kampfs diagrams. To get to a situation where the total Aerodynamic center of pressure is ahead of the CG, requires that the wing Lift (the forward green arrow,) be much further ahead of the CG Than is depicted. This is why the configurations above are not stable. The Wing Lift has a Significantly higher nose up pitching moment from AOA increase disturbances than the nose down pitching moment from increases in positive lift from the tail plane. Just look at video showing F-16 out of control for an illustration.
But just thinking about the definition of AC tells us all we need to know. The AC is defined as the point within the aircraft, that All lift can be treated as acting through for the purposes of calculating pitch moments.
So if this point (the AC), is ahead of the CG, then it is by definition unstable, because it's pitch moment (from the effects of all lift, from both wings and tailplane), is in the same direction as any disturbance. Just as shooting an arrow backwards would be.
The only way this configuration can be stable is if the total AC remains behind the CG. Aircraft with elevator controls in front (canards) can accomplish this because the Wing, which produces the bulk of the lift, is behind the CG, and canard (in front of the CG) produces significantly less lift. So the total AC remains aft of the CG. In a conventional aircraft, where the main wing is ahead of the elevator control surface, this is not easily possible. If the main wing is behind the CG, then it will produce a nose down pitch moment, and the tailPlane must generate negative lift to balance pitch moments. If the main wing is far enough forward of the CG to put the overall AC also ahead of the CG, its Nose up pitching moment will (by definition, since the AC is ahead of the CG), be greater than the opposing pitching moment from the tailplane. The only way this configuration can be stable is if the Main wing AC is only slightly forward of the CG, but not far enough forward to place the overall AC in front of the CG. Designing an aircraft so that these attributes remain in this narrow band is problematic, and so, I believe, is not the normal aircraft design approach.
All discussion above about the effects of the camber on the airfoils are irrelevant. Regardless of the camber, or downwash, There is still a total aerodynamic center, through which all forces can be considered to act through for the purposes of calculating pitch moments (and by implication static longitudinal stability). and if this AC Is ahead of the CG, the aircraft is statically unstable, and will fly out of control unless the stability is augmented by other mechanisms (like FBW).
1$\begingroup$ It is, however, theoretically possible to suspend the CG between the fuselage/wing and horizontal tail individual ACs (both creating positive lift) in a way that total aircraft AC is still behind the CG. The above would require a very narrow CG band to achieve this, but it is theoretically possible and the configuration would be stable. $\endgroup$ Jan 8, 2018 at 21:00
$\begingroup$ @Cpt Reynolds, yes - theoretically possible, but unlikely, (I believe you would have to do the actual math calculations to establish the conditions that would make this possible), but this scenario would be very unusual and not a common arrangement. Clearly, an aircraft using a canard configuration can be designed this way. so although without doing the actual math, I can't be certain, I think that some value of the ratio between the wing area of the forward airfoil and the rearward airfoil might be a threshold beyond which this condition is possible. $\endgroup$ Jan 9, 2018 at 2:48
$\begingroup$ Also, to make it absolutely clear as to what the disagreement is here, (I hope this is accurate, as positions sometimes change as clarity develops), I am not saying this is impossible, I am only saying that in conventionally designed aircraft (where the pitch control surface is at the tail), this is not the case. What I arguing against is the idea that it is always the case that the tail is generating positive (upwards) lift, and that it is false that reducing static margin or relaxing positive stability will reduce drag & increase range/endurance performance. This is what I am refuting. $\endgroup$ Jan 9, 2018 at 2:58
$\begingroup$ Mate - some of what you say has validity, but please leave out the negativity and the rants. $\endgroup$– KoyovisJan 9, 2018 at 11:57
$\begingroup$ @Koyovis, I apologize if I have created the impression of a "rant", or negativity. I do not mean that sarcastically. I know my passion sometimes creates inaccurate impressions about my intent. None of it is anything more than passion about the topic and frustration when I feel I am failing to communicate successfully. And, thank you for apparently reading my comments with enough thoughtfulness and open-mindedness to recognize some of what I am saying. $\endgroup$ Jan 9, 2018 at 15:54
