I have seen a WW2 movie where the pilot of the Supermarine Spitfire has difficulties to extend the landing gear as the engine is no longer running.
This would be reasonable if the gear normally needs hydraulic or electric power to be extended, otherwise probably just an attempt to add more tension to the plot. Would running out of fuel (no engine power) make the extension of the Supermarine Spitfire landing gear more difficult or different from usual?
