From the pilot perspective I want to know how to deal with the noise in the cockpit on the turboprop aircraft while long-run flights.
The reason is old type aircraft with bad headphones which doesn't protect from noise than they should be.
  • $\begingroup$ Are you not allowed to user your own headset? $\endgroup$ Commented Dec 29, 2017 at 21:36
  • $\begingroup$ The problem is that headset is very old, reducing noise approximately to 70%. $\endgroup$
    – wiaim
    Commented Dec 29, 2017 at 21:52
The most common way to deal with noise in the cockpit is to get yourself a noise canceling headset. There are a bunch of models out there but the most common seem to be the Bose and the Lightspeed. I personally have the lightspeed and will attest to at least a 30%-50% perceived noise reduction over my old passive headset.
  • $\begingroup$ I have the problem with connector which doesn't allow to install new headset. AN-26 aircraft $\endgroup$
    – wiaim
    Commented Dec 29, 2017 at 21:51
    $\begingroup$ If the most common way of dealing with noise doesn't work for you, that's something you should definitely state prominently in the question. $\endgroup$
    – yshavit
    Commented Dec 29, 2017 at 22:01
    $\begingroup$ A decent electrical engineer should be able to fabricate a conversion plug to allow a modern ANR headset to work in that aircraft. Well worth the money, imho, in order to preserve your hearing. $\endgroup$
    – Ralph J
    Commented Dec 29, 2017 at 23:42
