Suppose you have a Cessna 208 Grand Caravan Amphibian and you want to use VORTAC stations on military bases (or somewhere else). Is it possible? Is it legal?
1$\begingroup$ It's legal. Tuning a VOR signal is different to area based restrictions. If the wanted the signal restricted, they would encrypt it like some GPS signals. $\endgroup$– Rodney HawkinsDec 25, 2017 at 19:26
4$\begingroup$ @RodneyHawkins I don’t think it is possible to encrypt a VOR signal, which is what you are tuning to when tracking a VORTAC. If they wanted to restrict civilian use they would put in a TACAN and leave off the VOR. $\endgroup$– JScarryDec 25, 2017 at 19:58
Totally legal to tune it up & use it. If it is a VORTAC, it will work just like every other VORTAC out there. If it is a TACAN, you may be able to get DME from it, but you won”t get bearing from it without a TACAN receiver.
Many, perhaps most VOR’s out there are in fact VORTAC’s — the TACAN station is colocated with the VOR. It is possible to have a VOR-DME station, which gives a civillian user everything a VORTAC does, but no bearing info to TACAN-only military aircraft. And you can have a VOR station with no associated DME at all.
But you won’t find any rule prohibiting you from tuning up any of the above - doesn’t exist (at least in the U.S., nor anywhere else I’ve ever heard of). If the military wanted a NAVAID they could use that you couldn’t, they could put up a TACAN using a channel that civillian DME receivers can’t pair with (ex ch 16X “pairs” to 135.9 - not a frequency in the range civil VOR receivers can tune to) and not publish it. But realistically, they’d probably just use a GPS coordinate & call it good.
(Edit: as @UnrecognizedFallingObject mentioned, it is not the “Y” TACAN channels that conventional VOR receivers can’t pair with, but there are some channels you can’t get DME from using normal VOR tuning — see this chart.)
Flying over that navaid on a military base may entail issues with the airspace involved, but that is its own issue, unrelated to using or not using the navaid.
4$\begingroup$ BTW: it seems that most DME receivers can use Y-channels (you'll see plenty of civil DMEs published as "Chan 54(Y)" or whatever, see the I-SAJ DME used with the ILS for KORD RWY 09L for ex.) $\endgroup$ Dec 25, 2017 at 23:03
2$\begingroup$ @UnrecognizedFallingObject - Good catch! Looks like the X channels pair up to frequencies like 112.30, while the Y channels pair up with .05 higher, so 112.35. Edited post above to reflect that. $\endgroup$– Ralph JDec 25, 2017 at 23:21
Absolutely. A VORTAC is nothing more than a VOR colocated with a TACAN. Most VOR-DMEs in the US are VORTACs. If there happens to be one located on a base you are certainly still able to use it.
Short answer: A VORTAC station combines a VOR-DME and a TACAN. It is the result of a cooperation between civil and military worlds to share the same DME (and the navaid place).
Civil aircraft use includes accessing the VOR part (civil), the DME part (civil and military), but not the TACAN bearing transponder, said otherwise they access the VOR-DME equivalent, or for what civilians are concerned, a VORTAC is a VOR-DME.
They are not equipped for receiving the TACAN bearing equipment, though nothing prevent them to be equipped with the related UHF receiver.
More details: A VORTAC station is composed of three signal generators:
- A VOR (VHF) signal used for civil bearing determination.
- A DME (UHF) signal used for range determination
- An UHF signal used for military bearing determination, in theory 9 times more accurate than a VOR.
DME and UHF bearing station components are interrogated by the aircraft, contrary to the VOR which broadcasts continuously.
When civilians use a VORTAC, they actually use the two first signals (VOR-DME). Military use the two last signals (TACAN) and the VOR as a backup if they are equipped, which is normally the case.
Pure TACAN have only the UHF bearing determination signal and the DME signal.
Their little size, compared to a VOR-DME, allow them to be used on ships. More: Wikipedia article on TACAN, and How does Tactical Air Navigation work?
