I have had lens replacement surgery and now one eye is focused at 16” (close, reading distance)and the other eye is focused at a distance. I have 20/20 vision both at 16” and at distance as long as both eyes are open.
I have a third class private Pilots license and my medical is due. Can I get a waiver because I don’t meet the 20/40 requirement with either eye closed?
For example when my left eye is closed I can not meet the 20/40 requirement with my right eye when it comes to the 16” test and the same goes for my other eye when it comes to the distance test.
  • $\begingroup$ Do you need the third class, or can you get BasicMed? $\endgroup$
    – Ron Beyer
    Dec 21, 2017 at 15:13
If you are a member of or join AOPA I recommend consulting AOPA member services for help with questions like this. I have consulted them multiple times and they always get a good answer for me or set me in the right direction.
Of course you can consult an Aviation Medical Examiner (AME) first but I recommend you figure out what you need to do and go into your AME knowing you’ll pass the medical exam... once you’ve failed it can be a nightmare to get your medical back and take a long time (and cost lots of money).
Source: I’m a pilot who has used this service of AOPA before
