This question is related to the answer I found on this particular thread, about the Frames in a Turbofan.
In a turbofan what holds the spinning axis?
I went on this thread after some research on Google, since recently I started working in the industry. I'm working on this particular part of the frame, and I would like to understand more about it. Also I am currently working on understanding more about jet engines in general and how they work, I find this absolutly fascinating since I found a lot of information and answers to my questions - and now for the curiosity :)
My question is about the Fan Frame here (GE CF6/CFM56 Turbofan on pics)
I would like to know the use of the 12 Circular Holes on the inside of the frame, between the 2 flows (Low-pressure compressor way, Right?), you can see here what i'm talking about on those pictures (Red arrows).
(I don't think this is to make the part lighter, because the outside edges of thoses holes, are re-inforced a lot with a big extra thickness.)
CF6 Fan Frame. enter image description here
Thank you.
    $\begingroup$ A very nice first question! Welcome to Aviation Stack Exchange. If you haven’t already, can I suggest taking the tour and reading the help center so you can learn how this site works and continue contributing quality material like this. $\endgroup$
    – Notts90
    Commented Dec 17, 2017 at 9:24
15
Short answer
These holes are vents used to discharge air from the primary (core/hot) flow into the secondary (bypass/cold) flow. They are normally closed by valves (variable bleed valves, VBV). The valves open to maintain the compressor pressure/flow within a safe area.
VBV in operation: Youtube
CFM56-5A VBV in operation
VBV on a CFM56-5 (also visible the VSV). Source
VBV are a mean to prevent a compressor stall in turbo-engines. A stall appears in situation like this:
  • For some reason, e.g. when thrust is reduced, pressure at the compressor exit exceeds by a large amount its inlet pressure.
  • When the pressure ratio is beyond the compressor capability, air at the exit starts opposing compressor airflow, a reverse pressure wave is created, which propagates to the inlet.
  • Flow over one or more compressor blades is disturbed and the airfoil stall angle is reached creating an aerodynamic stall.
  • The stall is extended to the next blades, i.e. a rotating stall develops.
  • The pressure ratio is getting unstable.
  • Thrust is suddenly reduced, attempts to increase thrust accelerate the stall.
The VBV are used to adjust the compressor pressure ratio, by discharging some air between the LPC and the HPC. This decreases both the pressure ratio of the LPC and HPC and helps preventing compressor stalls.
Holes location
The fan frame assembly shown here without its outer shroud:
CFM56-7B fan frame assembly
Fan frame assembly, without its outer shroud, of a CFM56-7B. Source
comprises two rings of 12 stationary vanes which are crossed by:
  • The primary (core/hot) flow for the inner vanes
  • The secondary (bypass/cold) flow for the outer vanes.
The 12 holes/vents in the mid-box structure of the fan frame assembly are closed by 12 variable bleed valves (VBV):
CFM56-5A VBV mechanism
VBV in a CFM56-5A. Source
The valves are protected by a grille:
Source
Location of these elements in the engine:
CFM56-5 fan frame assembly and variable bleed valves
Location of the fan frame in a CFM56-5. Source
Details:
VBV on a CFM56-5. Source: CFM56-5 Training Manual
The master valve is controlled directly by a motor, the other valves are linked to the master VSV by a flexible shaft.
  • 5: Fuel gear motor powered by HMU, controls position of the master VBV
  • 1: Master VBV
  • 2: Position feedback
  • 4: Position sensor
  • 7: Flexible shaft controlling the other valves
VBV use
As regard to the cold flow, the inner duct is located between the low pressure compressor (aka booster) and the high pressure compressor. The pressure delivered by the compressor section is optimized for maximum engine power.
When the engine speed is low or the engine is decelerated, the LP compressor pressure can increase and clear the LP compressor stall margin. In such a case, the VBV are opened to release some air into the secondary flow and restore the margin. Conversely, when thrust is increased, the risk of stall disappears, the valve is closed to restore efficiency. The following diagram shows how the action on the valve contributes to keep the compressor flow in the designed working area.
Stall prevention using VBV Stall prevention using VBV. Source
More on VBV and stall prevention:
VBV for debris rejection
On military aircraft, unsuccessful attempts have been made to use VBV to capture and reject debris and water. The principle is to create a bend in the airflow with an opening at the start of the bent section. Heavier elements are captured by the hole. CFMI has reintroduced this technique in the LEAP engine.
