In an emergency course reversal, passenger safety first priority, to avoid say, a column of ash from a new volcano, what it the most G a 747 can withstand with an average passenger complement?
    $\begingroup$ "Withstand" as in, before you break the wing spar or some other necessary component? That all depends on the fatigue history of the aircraft and its exact gross weight. Unless you're pulling hard to avoid a SAM, nobody wants to go that far beyond the operating limitations of the flight manual. I suspect that 60 degrees, which is 2 G's, is as much as anybody would really use. But I'll defer to @Terry for the actual 747 driver's answer! $\endgroup$
    – Ralph J
    Dec 15 '17 at 16:23
    $\begingroup$ Also, once you leave level flight, you're sorta guessing at your G-loading. Level, G-loading maps to bank angle, although not (at all) in a linear way. With a descent - the quickest way to make a 180, assuming you have terrain clearance - you can bank quite a bit & maintain a low G-load if you're willing to accept the lost altitude & gained speed. But without a G-meter (not typically found in airliners!) or a highly calibrated seat-of-the-pants, you don't KNOW how much G you're pulling. You can estimate, but you don't know -- unless you regularly pull 2, 2.5, 3, etc outside of airline flying. $\endgroup$
    – Ralph J
    Dec 15 '17 at 16:33
    $\begingroup$ Don't the EASA and FAA specs require a minimum load factor of 2.5 for a large plane? And back from school I remember an aerospace safety factor of 1.5. So I'm guessing maybe 4 to 4.5g. $\endgroup$
    – user7241
    Dec 15 '17 at 19:45
    $\begingroup$ @RalphJ What is the exact process of calibrating the seat of your pants? :P $\endgroup$
    – TomMcW
    Dec 15 '17 at 20:52
    $\begingroup$ Nowadays the flight control computer would prevent the pilot from exceeding a certain limit load factor. So the aircraft structure could handle more, but the computer won't let him. $\endgroup$
    – user7241
    Dec 15 '17 at 23:53
It depends on how you define :withstand". China Airlines flight 006 experienced vertical load factors of up to 5.1 g on 19 February 1985. The aircraft could be landed safely and there were no fatalities, but there was considerable damage:
enter image description hereImage source
From the NTSB incident report:
The wings were bent or set permanently 2 to 3 inches upward at the wingtips; however, the set was within the manufacturer's allowable tolerances. The left aileron's upper surface panel was broken and the trailing edge wedge was cracked in several places.
The maximum load factor an aircraft can be subjected to is a function of time. Two cases are determined for civil aircraft:
  • Limit load factor. For transport aircraft weighing more than 50,000 lb (22,680 kg) this load factor is equal to 2.5, while for lighter aircraft it is a function of the weight.
  • Ultimate load factor = 1.5 times limit load factor, is the higher of the gust and the manoeuvre load factor.
The load factors are determined in accordance with the airworthiness regulations 14 CFR part 23.341 and 14 CFR Part 25.341. Damage tolerance of the airframe and the consequences of metal fatigue are stated in 14 CFR part 25.571.
The B747SP of the incident is an aeroplane that was designed and constructed in the 60s/70s, before Computer Aided Design and engineering were wide-spread, and the structures were designed with analytical mathematics and knowledge from experience, then tested for limit loads and ultimate loads. The more the design stresses can be modelled on a computer screen, the closer the wing ultimate load can be to 150% of limit load. Older aeroplanes did not have these modelling tools, and wings could end up to be stronger and heavier than they needed to be. Something that everybody applauds, but nobody wants to pay for with a higher ticket price.
A video of the B777 shows how the static testing for ultimate load is done: an actual wing is bent until it breaks. It is not a test of wing flex, it is a test of static strength.
The particular 747 of the incident had a wing designed for an MTOW of 378,000 kg, while actual MTOW of the 747SP was 320,000 kg: an extra load factor of 1.18. Fuel in the wing tanks provides extra bending relief, not for the ailerons though..
Civil aircraft certification requirements for airliners demand normal operations be possible up to 2.5g and down to -1g in clean configuration up to design manoeuvring speed, reducing above that speed. Googling EASA CS25 should show this for European-certified aircraft. The same design requirements furthermore specify that the structure must withstand loads in excess of these, but I am not quite sure as to the actual factors.
There have been accidents where design operational loads were exceeded which still ended with a safe landing.
    $\begingroup$ My question was right inline with the picture of the damaged aircraft. If the turn does not cause the craft to immediately break but allows a landing and saves everyone's life that is the G loading I was asking about. $\endgroup$ Dec 23 '17 at 15:56
In clean configuration, as has already been said, it's +2.5 / -1g, this is called limit load. Then you add on a 50% factor to yield the 'proof load', or ultimate fail load, which is proven in destructive testing.
But it's important to remember though, bits break by force, not G. G is just acceleration. So you have to multiply it by the aircraft weight to yield the shear force that breaks the wing root, spar, or whatever. That's why the limit load is applicable at Max Take Off weight. And also why a glider or aerobatic aeroplane can pull more G, because multiplied by the mass, the ultimate force applied to the components is lower.
    $\begingroup$ Welcome to AV.SE! Note that the best answers would be ones that add information not previously covered. $\endgroup$
    – Therac
    Jun 3 '20 at 10:34
