I've been looking at the pressure / velocity / temperature diagrams across jet engines. These have really helped me to understand the different roles that the compressor/turbine stator and rotors play, and how they compress and then extract energy from the gas flow. I then started thinking about the fan. I've done some reading on how propellers generate thrust in the same way as wings do, with the high and low pressure areas. My question is, do fans primarily generate thrust similar to propellers (i.e. with the high and low pressure areas), or do they operate more like the rotor and stator set-up, with the interaction of subsequent blades acting like nozzles to increase velocity?
$\begingroup$ What do you mean with the fan stator? $\endgroup$– KoyovisCommented Dec 6, 2017 at 10:43
$\begingroup$ @Koyovis - as you clarify below, the fan exit guide vanes. So I think my real question is, do the exit guide vanes transform internal energy of the air exiting the fan into kinetic energy like the turbine stator nozzles. However, the terminology of "exit guide vane" I assume parallels the intended use of the inlet guide vane, in that they change the direction of the air only - there is no change in energy form. $\endgroup$– qwertytamCommented Dec 6, 2017 at 14:13
$\begingroup$ Sure: aviation.stackexchange.com/questions/19664/… $\endgroup$– qwertytamCommented Dec 6, 2017 at 15:14
$\begingroup$ Also many discussions on airliners.net etc. $\endgroup$– qwertytamCommented Dec 6, 2017 at 15:15
1 Answer
The answer is kind of yes and no.
Actually the thrust is always the force with balances the pressure forces on all the parts of an aero-engine.
This means (clarification in the next paragraph) that both propeller and jet-engine "create" thrust with the pressure and suction side pressure distribution of the blades. The following picture from Rolls-Royce's The Jet Engine illustrates that nicely.
Actually nozzle and turbine create drag, because the pressure forces in them do not point into the direction of flight. (Thought-Experiment: Just imagine the bolts of the nozzle would fail: If the nozzle would create thrust it would stay attached to the engine. But as one can imagine the nozzle would fly away from the aircraft).
The nozzle is needed to control the pressure level of the whole engine in order to allow for the engine-process-cycle to work properly. And because of this link one can use momentum conservation to calculate the thrust based on the inlet and exit momentum (velocity) of the airflow.
Looking at a turbo-fan engine the answer stays the same. From the turbo machinery point of view: The fan does the same two things every compressor stage does. Two things: adding static pressure and whirl. The whirl is converted into pressure in the guide vanes, downstream of the fan.
From the thrust point of view: The fan-blades create the thrust, the stator-vanes (OGVs) down-stream of the fan-blades create drag. But as with the compressor and the nozzle above, without the OGVs the pressure-ratio of the fan would be lower and so would the fan-thrust.
One additional part is needed: The nozzle of the bypass. The above picture by JAXA nicely illustrates that (at least for modern engine installations) the bypass airflow is guided through a convergent-divergent nozzle.
So to sum up. Yes there is a pressure rise (at least locally) across the rotor and a velocity change as well. But the thrust (and drag) is produced by the pressure forces on blades and vanes (and all other engine parts). And yes the fan operates very similar to a rotor stator setup of a compressor. But the vanes in a compressor work like a diffuser, reducing the flow velocity. In order to keep the flow velocity mostly constant the annulus is shaped like a nozzle to balance the increased density.
1$\begingroup$ And now for a paradox: Let the bolts fail and the nozzle fly off: Without it, the engine will create less thrust. $\endgroup$ Commented Dec 5, 2017 at 19:02
$\begingroup$ @PeterKämpf: true, you might have added a "Spoiler-Alert" before the paradox. But of course you are right, without the pressure reduction in the nozzle the turbine would expand until it reaches ambient pressure which then would reduce the pressure (enthalpy) difference in the turbine requiring a lower pressure rise in the compressor which results in lower thrust. $\endgroup$– rul30Commented Dec 5, 2017 at 19:38
1$\begingroup$ @mins: True, I'll edit that, I focused on the question in the text and forgot about the question in the title, thanks mins. $\endgroup$– rul30Commented Dec 5, 2017 at 19:38
1$\begingroup$ not sure what caused the numerous down-votes. I am happy to clarify or change my answer, but without any comments that's hard. $\endgroup$– rul30Commented Dec 6, 2017 at 5:37
1$\begingroup$ The whirl is not important - the increased velocity is. Whirl is an unwanted side-effect after the rotor. It should get straightened out by the stator so that the direction of velocity is along the intended thrust line. $\endgroup$– user7241Commented Dec 7, 2017 at 3:40
