16
I understand that, at least for remote-controlled model planes, the control surfaces can point to a range of angles, say, from $-30^\circ$ degrees to $30^\circ$. My questions are:
  1. Would the same airplane work if the control surfaces can only point to, say, $-30^\circ$, $0^\circ$, $30^\circ$.
  2. If I rapidly switch the surface on ($0^\circ$) and off ($30^\circ$) like in pulse-width modulation (PWM). Is that equivalent to having the control surface pointing at $15^\circ$?
  • 10
    $\begingroup$ Early RC model airplanes worked that way. Just make sure you don't switch the control surface with anything close to a flutter frequency. The effect is not exactly equivalent, but close enough for coarse remote control. $\endgroup$ Commented Dec 3, 2017 at 23:17
  • 8
    $\begingroup$ Interestingly, the control surfaces of the GBU-12 Paveway II laser-guided bomb are actuated in such a bang-bang fashion. $\endgroup$ Commented Dec 4, 2017 at 5:44
  • 10
    $\begingroup$ Not really a full answer, but if you do that to the rudder of an Airbus A300, the vertical stabilizer breaks off. $\endgroup$ Commented Dec 4, 2017 at 9:55
    $\begingroup$ @TomCarpenter On/Off doesn't necessarily mean instantaneous maximum deflection. Slow deflection of rudder won't break the vertical stabilizer. $\endgroup$
    – user21228
    Commented Dec 4, 2017 at 11:14
    $\begingroup$ @qqjkztd Somewhat like the way most planes aren't limited to when they land in Sioux City? $\endgroup$
    – user
    Commented Dec 4, 2017 at 13:47
6 Answers 6
17
Theoretically it could work that way. A maneuver that needs a certain control surface deflection for a certain amount of time could be done with full 30 degree deflection in a shorter time.
Fine control and trimming would be more difficult. Small adjustments would require a very short time at full deflection. Control laws would have to take into account the step response of the system to determine how quickly the surface can reach the full deflection. By pulsing a deflection command like with PWM, you could determine a modulation that would keep the surface near some nominal deflection.
For an RC plane's systems this may be fine. With larger aircraft you would need to consider the effect of these large inputs into the control system, and structural effects, including whether 30 degree deflection is possible in the current flight conditions.
  • 11
    $\begingroup$ Very early model remote controls in the 1940s and 50s worked that way. Later, improved models would stress their "proportional" control to distinguish themselves from the earlier models. Just like temporal dithering is used for pixels, short pulses of full deflections can be used for control. There is even a special field of control theory for this. $\endgroup$ Commented Dec 3, 2017 at 23:07
    $\begingroup$ Also: from the passengers point of view, that would probably be very uncomfortable! $\endgroup$
    – kebs
    Commented Dec 3, 2017 at 23:33
  • $\begingroup$ Another issue is that response to control deflection is non linear. The response to a sudden large deflection of a control surface is not just larger than the response to a small one. Turbulence and non-Newtonian Dynamics can make it very different. $\endgroup$ Commented Dec 4, 2017 at 0:01
  • $\begingroup$ Use a keyboard as your primary controller. KEYDOWN = control on. KEYUP = control off. And yeah it's not a smooth ride. $\endgroup$
    – Joshua
    Commented Dec 4, 2017 at 4:16
12
I once had a very cheap electric ducted fan styrofoam RC plane that I found for sale at Woolworths sometime in the 90s that had "bang bang" flight control surfaces and throttle. In lieu of servos, it had a very light, weak solenoid with the control rod as its core.
I was a novice, but was able to get it to 'fly' a maximum distance of 20ft, bank either left or right as commanded, descend steeply or slightly less steeply by blipping the elevator, but never climb without instantly rolling into a knife edge dive. More of a slightly delayed crash than flight. But someone believed in the design enough to market and sell it.
Depends what you're talking about. Do you mean for the flight controls to actually slam all the way to stop, then center, then slam to stop, etc., violently slamming the aircraft around? (Terrible for fuel economy by the way, and hard on everything else).
Or do you mean to use PWM to select an intermediate position? E.g. 50% duty cycle gives you stable 15 degree rudder?
The trick is to put damping in the operating mechanism, and PWM at a frequency fast enough for the damping to do its job: before the surface physically gets a chance to move, the PWM reverses. The PWM is too fast to wobble the surfaces.
Then also either add some spring resistance so deflection will be predictable for a given duty cycle, or have an analog position sensor educating the PWM as to its effects. Air resistance varies with speed, and without something to equalize it, surfaces at a given duty cycle will deflect different amounts for different speeds. Of course, that could be made a "feature": as DJ319 points out, you actually want less deflection at higher speeds.
As many people have mentioned examples of where it has been used. I would just like to mention that on full scale aircraft the stresses involved in deflecting control surfaces to maximum deflection at cruise speeds (even for a fraction of a second) would probably result in structural failure. In addition to this those kinds of deflections would result in huge g-forces for the crew and any passengers possibly resulting in black outs or red outs.
I would then suggest that something like this could only be used for unmanned craft. Unless the max min values scaled with the aircraft velocity. For example at cruise instead of +-30 degrees of deflection you would have +- 10 to 15 degrees.
This has been done in WWII glide-bomb systems. However, since the idea isn't widely used, it presumably has practical disadvantages.
Yes, it could. The first guided bomb, the German Fritz X developed during WW2, used such a setup. They refined it a bit by oscillating the control surface from neutral to deflection rapidly, so that it wasn't a pure on/off control input.
This was a clever way to get around the limitations of tech of that day, that they weren't able to develop a porportionally adjustable control surface. They could, however, change the oscillation rate with the analog electronics they had available, which in effect gave some proportional control. The faster the surface oscillated, the greater the control input.
The Fritz X was very successful, sinking the Italian battleship Roma, and damaging several allied ships. It fell into disuse when the allies got full control of the air - the Fritz X was visually guided, and required a bomber to remain near the target while the bomb pilot guided it in.
