I have a list of positions (X [NM], Y[NM], Z[NM]) of an aircraft. Every coordinate is given every 1 second.
I calculate the speed [knots] between two consecutive coordinates in the following way:
$S_{i+1}=\frac{\sqrt{(X_{i+1}-X_{i})^2 + (Y_{i+1}-Y_{i})^2 + (Z_{i+1}-Z_{i})^2}}{1s}3600\frac{s}{h}$
It's basically space over time.
Does this 3D speed have a specific name?
    $\begingroup$ That's a trippy question :) $\endgroup$
    – Koyovis
    Nov 24, 2017 at 13:49
    $\begingroup$ I dunno what you are trying to solve for there. Yeah, technically it would solve for velocity, but I don’t know where such a calculation would be used in aviation. $\endgroup$ Nov 24, 2017 at 14:09
  • $\begingroup$ I don't want to try to solve anything... I just wonder if such speed has a specific name... it seems to me strange that there are definitions for ground speed, airspeed and so on but no definition for what I consider the most intuitive and basic definition an aircraft can have... $\endgroup$ Nov 24, 2017 at 15:26
    $\begingroup$ How is this not instantaneous ground speed ? $\endgroup$
    – Jeffrey
    Nov 24, 2017 at 16:26
  • $\begingroup$ Ground speed does not have the z-axis $\endgroup$
    – Koyovis
    Nov 25, 2017 at 11:00
It describes what the velocity vector of the aircraft centre of gravity is in relation to the surface of the earth. Ground speed is the 2-D projection of your speed on the ground, climb speed is the vertical component.
Both ground speed and climb speed are very useful parameters as such: ground speed to figure out when the aircraft arrives, climb speed to adjust engine settings etc for reaching cruise altitude with a minimum amount of fuel used. The 3-D vector sum of the two has little practical use, that is probably why it has no separate name as far as I know.
The integrated signal is of more use: what is the position in 3D of the centre of gravity of the aircraft relative to earth? Pretty useful for navigation.
