Please explain what is RTOW, and what is the difference between RTOW and MTOW. Is there a link between the RTOW and the Weight and Balance Manual?
  • $\begingroup$ What have you found so far? Related on PPRuNe: MTOW and RTOW $\endgroup$ – mins Nov 15 '17 at 15:19
  • $\begingroup$ Related if not duplicate: What are different types of weights of an aircraft? $\endgroup$ – Farhan Nov 15 '17 at 15:30
    $\begingroup$ @Farhan I don't think that question mentions RTOW? This one does, but only indirectly and it doesn't give a definition. $\endgroup$ – Pondlife Nov 15 '17 at 15:47
    $\begingroup$ @Pondlife Yes, you are right. I added it there too. $\endgroup$ – Farhan Nov 15 '17 at 16:10
Google gives you the answer without even clicking any links:
https://www.google.com/search?q=RTOW
MTOW is a hard limit regardless of other considerations and is tied up with the basic aircraft certification basis.
RTOW is the limiting takeoff weight calculated for a particular runway under particular specified conditions
Maximum Take Off Weight - The maximum weight in which an aircraft can ever take-off, under any circumstances.
Regulated Take Off Weight - The maximum weight in which an aircraft can take off from a particular runway under specific conditions (winds, weather, specific aircraft configuration, etc,). For example, runway 29 at KXYZ airport with ambient temp of 20° C. This can get as specific as you wish.
Of course $RTOW \le MTOW$.
    $\begingroup$ In addition, there is no direct relation between the RTOW and the weight and balance manual (WBM), other than that limits specified in the WBM might impose a restriction which the RTOW would have to consider. $\endgroup$ – Cpt Reynolds Nov 15 '17 at 16:11
