Where do I have to look to find out how much a passenger window of a Boeing 737 costs?
  • $\begingroup$ Welcome to Aviation.SE! The answer to your question depends on the specific aircraft variant (in your case, like the Boeing 737, 747, 777, etc), the airline, etc. You need to be much more specific to get a good answer. Also I don't think it is even possible to buy a window, as they are 'made to order' for that specific aircraft. I think the price can be found with a little effort though... $\endgroup$
    – user18035
    Commented Nov 15, 2017 at 6:52
    $\begingroup$ Sorry that I did not specify the aircraft model. I want to know for the Boeing 737 model. I need it in 90 ea. but want to know in the unit price. $\endgroup$ Commented Nov 15, 2017 at 7:24
    $\begingroup$ Out of curiosity, might I know why you need 90 windows of a Boeing 737? $\endgroup$
    – user18035
    Commented Nov 15, 2017 at 8:14
    $\begingroup$ I'm voting to close this question as off-topic, quotations cannot be provided. $\endgroup$
    – mins
    Commented Nov 15, 2017 at 11:54
    $\begingroup$ Just out of curiousity, did you accidentally break one and are feeling guilty about it, or what? $\endgroup$ Commented Jul 2, 2020 at 0:11
This page has declared values for part shipments, including one with the 140N2139-4, which is the assembly containing the seal, mid pane, and outer pane for the 737 NG. The declared value is 24,562 INR which is currently about 375 USD. A shipment of 20 also listed has a lower unit price.
For searching purposes GKN has part numbers in their catalog. You typically have to ask for a quote from suppliers.
Assuming that you are referring to a Boeing 737, here what you might be looking for:
But as these are made-to-order (as I mentioned in my comment), there is no MRP / MSRP - you have to directly contact them to get a quote. The actual unit price depends on your application, the quantity of windows you need, and other such factors.
EDIT: If certification isn't necessary, you might as well look for aircraft bone-yards, where you might get windows, which will be way cheaper than certified, made-to-order units. (Courtesy: @DanPichelman)
  • $\begingroup$ Dear Anand, Your provided info is very helpful. I want to know the unit cost but 90 ea. is the approx qty to estimate the best price. Anyway you have already help with the useful direction that how can I proceed. Thank you again for your attention. $\endgroup$ Commented Nov 15, 2017 at 8:30
    $\begingroup$ Now it is here, let's see what happens to the question. $\endgroup$
    – mins
    Commented Nov 15, 2017 at 12:38
    $\begingroup$ I wonder why someone who wants to buy 90 (!) Boeing windows doesn't ask Boeing. I mean, this isn't like "I want to buy one for display or decoration" $\endgroup$
    – PerlDuck
    Commented Nov 15, 2017 at 14:41
    $\begingroup$ If the OP doesn't require certified parts, a boneyard might be an option. $\endgroup$ Commented Nov 15, 2017 at 15:26
    $\begingroup$ Go ahead and add it $\endgroup$ Commented Nov 16, 2017 at 4:31
