At Fresno Yosemite International Airport (KFAT), I was instructed to taxi to RWY 29L via B11, B from Signature Support. When passing B3 and approaching RWY 29L end, I noticed there is one holding short line between B2 and B3 and the next one is on B2, I was confused where to hold short for the instruction (hold at the first anyways).
The one between B2 and B3 seems extra, but it is a double-solid-double-dashed line, which is also shown the Google Map the same I observed. I am wondering how this can well-define a runway protection area? Meanwhile, the first holding short line (the one between B2 and B3) does not mark which runway it protects. I also suspect it should have been ILS protection marking instead.
Google Map KFAT Airport
FAA Airport Diagram for KFAT
That’s a hold line for aircraft taxiing on Bravo while large aircraft are departing Rwy 29L to prevent aircraft from taxiing behind the blast pad for 29L and potentially being tossed around by the jet blast from the departing aircraft.
  • $\begingroup$ I am not sure I follow. Do you mean the hold line on taxiway B (b/w B2 and B3) or the one on B2? $\endgroup$ Nov 14, 2017 at 5:47
    $\begingroup$ Hold traffic cleared to taxi to 29R short of Bravo 2 for a departing aircraft on 29L. $\endgroup$ Nov 14, 2017 at 5:59
  • $\begingroup$ It makes sense that Line 1 is a hold line for Taxiway B2. I am still surprised to see a hold short line is marked when both sides are movement areas. $\endgroup$ Nov 14, 2017 at 6:14
    $\begingroup$ If atc wants you to hold at the first line, how would they say it? Would they say “hold short of B2” or what? $\endgroup$
    – TomMcW
    Nov 15, 2017 at 3:47
