Airplanes with a T-tail design have a shorter vertical stabilizer than the conventional design , what is the reason?
$\begingroup$ related: aviation.stackexchange.com/q/1400/1467 $\endgroup$ – Federico♦ Nov 13 '17 at 15:52
Two reasons:
- T-tail design is often imposed on designs with twin engines mounted at the aft fuselage. This means they have a small moment arm in the yaw direction, the vertical tail is dimensioned to compensate for engine failure. The further away form centreline the engine is mounted, the higher the yawing moment that the remaining engine exerts upon engine failure.
- The horizontal stabiliser at the top of the vertical stab functions as an aerodynamic barrier, like a winglet does. This prevents a vortex from streaming off of the top of the vertical tail when yawing, and thereby increases the effectivity of the vertical tail surface. This effect was researched in NACA TN 2907, at five different locations and three different spans:
The graph below shows calculated effective increase of aerodynamic aspect ratio, as function of where on the fin the horizontal tail is located. If completely at the top or at the bottom, the aerodynamic aspect ratio is about 50% higher than when at the centre, resulting in increase of the lift curve slope of the fin of roughly 15%.
With a T-tail, the horizontal stabiliser at the top functions as an aerodynamic barrier, while the fuselage at the bottom end provides some barrier function as well. Depending on the local fuselage circumference and shape of course.
1$\begingroup$ The last plot does not seem to show what you say. It appears that placing the wing at station A (bottom) or E (top) give the same effective aspect ratio, both 50% better than placing at the midway up the vertical stabilizer. This makes sense to me -- shouldn't the endplate effect work on either end of a lifting surface? $\endgroup$ – supergra Oct 3 '19 at 17:28
$\begingroup$ Does the first bullet point reverse cause and effect? I thought it's not so much that a T-tail is imposed when you have fuselage-mounted engines, bit rather that it necessitates a shorter tail, which in turn requires fuselage-mounted engines (so that the moment is lower). Or alternatively, That it's enabled (not imposed) by that engine configuration. $\endgroup$ – yshavit Oct 4 '19 at 7:58
$\begingroup$ Another reason according to Wikipedia is to reduce inertial coupling. I haven't understood so far how that works – can you shed some light on the issue? $\endgroup$ – Peter Kämpf Oct 5 '19 at 0:11
Raymer gives the following answer:
The 'T-Tail' is also widely used. A T-tail is inherently heavier than a conventional tail because the vertical tail must be strengthened to support the horizontal tail, but the T -tail provides compensating advantages in many cases.
Due to end-plate effect, the T -tail allows a smaller vertical tail. The T -tail lifts the horizontal tail clear of the wing wake and propwash, which makes it more efficient and hence allows reducing its size. This also reduces buffet on the horizontal tail, which reduces fatigue for both the structure and the pilot." (pg. 69)
- D. P. Raymer, 'Aircraft Design: A Conceptual Approach', AIAA, Washington DC, USA, 1992.
