I'm not familiar with Jepp plates but as far as I can see both plates are the same, it's just that Jepp chose not to depict ACUBO on the base area icons (as the FAA calls them). I assume that's to reduce clutter on the chart but I don't know for sure. In any event, I don't see how it would change the procedure in any way: all the fixes are still shown on both plates, and all the details seem to be the same.
As for the HILPT, the rule for procedure turns is that by default you have to fly them unless you have a valid reason not to (see this question). In the case of this approach, the plate says NoPT if you're approaching from the straight-in area or on the direct tracks from CADAC/BEBAC to ACUBO. If you get to ACUBO any other way, you have to fly the HILPT. The most likely reason would be that you're coming from the south and ATC vectors you directly to ACUBO rather than to CADAC or BEBAC: "N12345, proceed direct ACUBO, cleared for the RNAV 19R approach".
The FAA Instrument Procedure Handbook (chapter 4, p. 4-58) has detailed information on TAAs, including this:
ATC may clear aircraft direct to the fix labeled IF/IAF if the course
to the IF/IAF is within the straight-in sector labeled “NoPT” and the
intercept angle does not exceed 90 degrees. Pilots are expected to
proceed direct to the IF/ IAF and accomplish a straight-in approach.
Do not execute HILO course reversal. Pilots are also expected to fly
the straight−in approach when ATC provides radar vectors and
monitoring to the IF/IAF and issues a “straight-in” approach clearance;
otherwise, the pilot is expected to execute the HILO course reversal.
But even if ATC vectors you to ACUBO they can't give you a straight-in clearance if your intercept angle is greater than 90 degrees (ATC Orders 4-8-1(d)
and (e)).
You also asked in a comment what happens if ATC clears you for the approach without specifying the IAF. That's explained in the IPH:
On rare occasions, ATC may clear the aircraft for an approach at the
airport without specifying the approach procedure by name or by a
specific approach (e.g., “cleared RNAV Runway 34 approach”) without
specifying a particular IAF. In either case, the pilot should proceed
direct to the IAF or to the IF/IAF associated with the sector that the
aircraft will enter the TAA and join the approach course from that
point and if required by that sector (i.e., sector is not labeled
“NoPT), complete the HILO course reversal.
