I have a few brushless motors and I am trying to get the best thrust out of each motor. I am busy doing some research but can't get a clear answer. What would be the best fan duct design to achieve maximum thrust?
Project: mini hover bike prototype with 2 or 3 motors. Duct size doesn't matter at this point.
    $\begingroup$ obviously the most efficient choice is no duct but use a prop, especially you when you don't care about size $\endgroup$ Oct 24, 2017 at 19:22
    $\begingroup$ @user3528438 Not necessarily. Shrouded propellers do deliver higher thrust than unshrouded ones, especially if the clearance between propeller and duct is very low. $\endgroup$
    – Koyovis
    Oct 24, 2017 at 23:46
  • $\begingroup$ It all depends on the specific setup for the motor and props. With the correct setup you can increase thrust and reduce power consumption by to 50-60%. (so I have read). I'm going to use @Koyovis research and 3D print some test ducts and props. $\endgroup$ Oct 25, 2017 at 12:01
  • $\begingroup$ You could take a look at the ducting on the Moller flying car also moller.com The M200 had 8 ducted fan motors. moller.com/brochures/Neuera-Brochure.pdf $\endgroup$
    – CrossRoads
    Apr 10, 2018 at 18:50
  • $\begingroup$ "The M200G Neuera Volantor A revolutionary 2-passenger VTOL ground effect vehicle" Wonder if electric motors could substitute for fuel powered motors now? Battery technology has come a long way. $\endgroup$
    – CrossRoads
    Apr 10, 2018 at 18:56
It's not easy to find research on small ducted fans. I did come across this interesting masters thesis from 2009, which does show some relevant results - at low propeller speeds.
Duct design
The document describes three duct designs, one with a variable bypass inlet and two simpler ones. The simplest one is made from PVC tuning and a foam inlet lip:
Geometric information is given as:
  • Inner diameter = 14.5"
  • Duct Chord = 4"
  • Duct Length (C/D) = 0.28
Maximum Thrust
One of the results of the project is that a ducted propeller delivers more thrust than an un-ducted one. Here is one of the results, listing $C_T$ as a function of tip Mach numbers - which are really low and therefore hard to generalise into practical rotor and fan configurations.
Tip Clearance
Best results were obtained with a propeller with square tips with the smallest gap between propeller and duct that could be achieved. This was a 3-blade propeller, but the research project was severely limited by the small motor used, and therefore low maximum torque that could be exerted on the propellers.
  • $\begingroup$ Thanks, great answer! The information and linked document will definitely push me in the right direction. I guess there is no 1 answer as every motor, prop, number of blades, motor torque etc. differs. $\endgroup$ Oct 25, 2017 at 11:56
