On the a320, can someone explain why this is:
AMM 27-22-00 PB 001
NOTE:The maximum admissible rudder trim limits indicated on the control panel when the aircraft is stabilized in heading with the AP engaged are RH 1 DEG and LH 2.3 DEG.
Why is there a 1.3 difference in deg between LH & RH?
