Consider a max forward and a max aft CG position.
    $\begingroup$ Wouldn't it be easier if you just name the textbook and let us know which of your homework questions we should answer? $\endgroup$ – Peter Kämpf Oct 6 '17 at 15:34
  • $\begingroup$ I wish there is a textbook for it. $\endgroup$ – Aishve Torah Oct 6 '17 at 16:16
    $\begingroup$ Maybe this will help. courses.cit.cornell.edu/mae5070/DynamicEquations.pdf $\endgroup$ – Juan Jimenez Oct 11 '17 at 20:24
  • $\begingroup$ Any flight dynamics or aircraft design text book can help you here. Check out Torenbeek, Etkin or Roskam. Basically if all you need is the force required and not control surface deflection or tail size all you need to do is a moment balance about the aircraft CoG $\endgroup$ – DJ319 Oct 18 '17 at 8:53
