Aft movement of the control column deflects the trailing edge of the elevator surface up. This is usually referred to as the up-elevator position. The up-elevator position decreases the camber of the elevator (my emphasis) and creates a downward aerodynamic force, which is greater than the normal tail-down force that exists in straight-andlevel flight. The overall effect causes the tail of the aircraft to move down and the nose to pitch up. PHAK 6-5
This is an excerpt from PHAK on the elevator. Do you agree with the statement "the up-elevator position decreases the camber of the elevator"? I've always thought the camber of control surfaces indicates their curvature, which is designed by aircraft designers or controlled by pilots using high-lift devices, and it is the angle of attack that that changes when pilots give control inputs. So isn't it more correct to say "The up-elevator position decreases the angle of attack of the elevator"?
