Our Piper PA28-181 doesn't want to let us communicate via its own intercom panel in the dashboard. We connect via the pilot port and an "Intercom SL300". When connected there is a annoying sound on the phones, it seems to be the strobe or ignition (going to test it).
My questions:
  • Where would I get information regarding the intercom/audio wiring in old and small airplanes?
  • Is it possible to install a suppression capacitor?
  • $\begingroup$ Basic question: does the sound go away when you use squelch? $\endgroup$
    – GdD
    Oct 3, 2017 at 8:27
For the wiring, you need to do several things. First, obtain the Vendor's manual for the SL 300. Next you will need to trace out the wires going to the SL 300. I suggest labeling them.
This type of work is beyond normal pilot/owner maintenance, and I would urge you to work with your A&P or avionics shop tech to get support while you debug things, and also to provide guidance as you navigate the wires, controls, etc. that might need some displacement while you work on things.
A suppression capacitor can be installed, but I would identify the problem first. Again, the avionics tech should be consulted, and any filter you install will need to be documented, and "signed off" but you probably already know this as you own the plane.
Give a better description of the sound, or a recording, and you might get better ideas on where to look.
