Over the years I've heard the two used almost interchangeably but after watching some videos it would seem that they each have specific and particular functions.
5 Answers 5
Both chaff and flares are defensive countermeasures deployed by military aircraft. The purpose is to confuse radar-guided or infrared-guided anti-aircraft missiles fired so that they can divert.
A good definition about them is here:
Chaff is composed of millions of tiny aluminum or zinc coated fibers stored on-board the aircraft in tubes. When an aircraft is threatened by radar tracking missiles, chaff is ejected into the turbulent wake of air behind the plane.
Flares are used to distract heat-seeking missiles. Most are magnesium pellets ejected from tubes to ignite in the wake behind the aircraft. These flares burn at temperatures above 2,000 degrees Fahrenheit, hotter than the jet engine nozzles or exhaust and exhibit large amounts of infrared light.
Flare
Flares are a, let's call it "passive defense system". They are used for misleading rockets fired on an aircraft. Many missiles are following a heat source to hit their target. In case of an aircraft, it's the engine. If such a missile is on the way, the pilot fires those flares. They burn really hot and the missile will fly into the flare instead of the aircraft.
Aircraft flaring gun
Source
Chaff
Chaff is also spread out by aircraft. There are used for, what can be called "electronic war". As you know, a radar sends out electromagnetic signals. If they are being reflected to the radar, there is a dot visible on the radar. This can be an aircraft but also lots of birds. Now, chaff is made of aluminium or metallized glass fibre or plastic. So, when the aircraft spreads a big cloud of that chaff, it is visible on the radar. And this can work like a curtain. There is a wall of chaff sprayed out. Behind that wall, every aircraft is invisible and operations can be accomplished secretly.
But chaff can also be used as "flare" but for radar-assisted systems. Like radar-lead missiles or radar-targeting systems by fighters.
Chaff
Source
    $\begingroup$ Rockets are unguided, I think you mixed up with missiles. $\endgroup$
    – Cypc
    Commented Oct 3, 2017 at 15:46
    $\begingroup$ @Cypc Yea, thank you. In german "rocket" and "missile" is the same, so I mixed them up. $\endgroup$ Commented Oct 3, 2017 at 17:24
They both belong in the category of countermeasures, but let's say that they... target different audience. Chaff is used to spoof radar guided (active or semi active) missiles. Flare is used to spoof heat seeking (passive) missiles.
Chaff pods contain several small metallic parts of similar size and shape and their aim is to create false returns to the radar beaming the targeted aircraft. The sized and shape depends on the radar wavelength they try to spoof but I am unaware of the exact relationship.
Flare on the other hand targets heat seeking missiles. As user3528438 mentioned in their comment, they are "fireworks" that aim to create a brighter thermal image and drive the missile away of the aircraft's thermal trail.
The tricky part for the pilots (and perhaps the modern warplane designers) is to distinguish between the type of the homing missile, so that they use the right countermeasure for each threat without wasting consumables. That's probably the reason you've heard them as chaff/flare like there is no difference.
There are two ways for an anti-air missile to "see" its target:
  1. Radar signature : the missile is fitted with a radar receiver, so when the launching plane illuminates his target with his radar, the missile get the signature and can go to the target. (Some more advanced missiles even have their own little radar emitter and receptor for the last part of their guidance.)
  2. Heat signature : the missile is fitted with a heat seeker, and will follow the eat source he was assigned by the launching plane before firing.
Chaffs are designed to defeat the first category, flares the second :
  • Chaffs are small pieces of material that will reflect radar waves in different directions. Their goal is to disrupt attacker's radar so he can not guide his missile or will guide it on the chaffs, not the defending plane. They do not produce any smoke and are really difficult to see visually.
  • Flares are small pieces of material that will produce a lot of heat, trying to blind / confuse the enemy eat seeking missile, making him think one of the flare is in fact the planes engine.
In both cases they are employed to try to divert a missile from his target.
Flares are normally pyrotechnic devices designed to create a large IR signature to capture IR targeting on missiles.
There are two common types of chaff. The most common is metal based and is reflective, designed to create a field of reflections and capture the radar receiver. They are not necessarily foolproof. For example, their velocity drops to the ambient wind velocity within a few seconds, were as an aircraft will continue to depart at a flight velocity. Also, metastatic radar and other techniques may see around / through them.
There is also IR chaff (also a pyrotechnic measure) which is designed to create a field of temperature, reducing the signal to noise of the targeted aircraft (or other target) and decreasing the capture and hold on that target. The effectiveness of IR chaff is similar to RF chaff as reported by several sources.
    $\begingroup$ Could you include a source on the IR chaff? A cursory search doesn't seem to bring it up. $\endgroup$ Commented Oct 3, 2017 at 15:08
  • $\begingroup$ @AEhere sure. Just had a student do a paper on IR chaff. There are many DTIC papers, but an open reference is: EW 102, David L Adamy, (2004) page 105. Keep in mind that chaff is different from flares, in that flares are larger devices and chaff is small. This means that flares generally are sensed as point sources, and chaff is rather a distributed region. $\endgroup$
    – mongo
    Commented Oct 3, 2017 at 18:28
