20
I have heard the following terms related to safe system design but I cannot really see a difference between fail-safe and fail-soft (graceful degradation).
To get a common understanding I will just write out the terms that I've heard. Please feel free to correct me, if I don't explain something properly:
  • Safe life: A system does not show any fault during its lifecycle
  • Fail-Safe: A system goes into a safe operating mode with reduced functionality after a failure
  • Fail-Soft: A system goes into a degraded mode after a failure
  • Fail-Operative: A system still has the full functionality after a failure
From those explanations, it seems to me that Fail-Safe and Fail-Soft are actually the same concepts. I would be glad if someone could explain to me the difference between the concepts by using some examples from aviation.
  • 8
    $\begingroup$ Fail safe does not require system to operate at all. $\endgroup$ Sep 18, 2017 at 14:16
    $\begingroup$ Good example of fail-safe system outside aviation context are railway brakes. In passenger car force is applied to engage brakes, so when hydraulic system fails, you cannot use brakes to stop your car. In trains, however, brakes in neutral state are engaged and force is applied to hold them off. So any failure in power delivery engages them and halts the train pushing it into safe state - that's what makes them fail-safe, despite they are not "operable" nor have any functionality in failed state. $\endgroup$ Sep 19, 2017 at 6:02
  • $\begingroup$ And safe-to-fail? $\endgroup$
    – neverMind9
    Jul 11, 2018 at 10:22
31
Fail-safe does not necessarily imply that the system will continue operating after a fail. If the system stops operating but does not create a dangerous situation, it is still fail-safe. A non-essential service on board an aircraft such as the entertainment system can be fail-safe if it just stops operating because a fuse blows. If upon a failure the fuse does not blow and as a result the system catches fire after a short-circuit, it is not fail-safe.
Fail-soft does indeed mean that after a failure, essential services are still functional, although in aviation context this is mostly referred to as graceful degradation. A fly-by-wire system such as on board the A320 is fail soft:
  • If all flight computers are functioning, the system flies with normal law active, providing protections against getting into unsafe regions of the flight envelope.
  • Upon certain detected failures, the system switches to alternate law, still with some protections in place.
  • Upon further failures, the system switches to direct law: no more flight envelope protections, just surface deflection proportional to stick deflection.
So this flight computer system is fail-soft and fail safe. The electronic flight control system as a whole is fail safe: if all flight computers are lost, the system has hydro-mechanical connections from pedals to the rudder and from the trim wheel to the stabiliser.
Hydraulic systems require special attention regarding fail-safety, since a stuck servo valve can command a constant velocity: the actuator runs into one of its stops and has a hard-over failure. An elevator that is stuck in full up deflection is not safe, so the pitch control system needs to make provisions for fail-safety if this fault occurs. For instance by allowing left and right elevators to normally work in unison, but uncoupling them after a detection of a hard-over failure. The working elevator can then be commanded to full opposite position, making the elevator system fail-safe but not fail-soft: pitch command must now be done with the stabiliser trim. One elevator stuck in the mid position would be fail-safe, and control with the other elevator provides graceful degradation.
The flight control system on board an F-16 is fail-operational: upon a system failure, full system function continues, no degradation. It is triple redundant, meaning there are four systems on board that carry out the same function, while only one is required. The four systems function independently, and a monitoring system determines if all four outputs are within a pre-determined range. If three are and one is not, this system is switched off and the other three continue. This can happen once more, but if there are only two systems operational the voting system would not know which of the two has failed.
    $\begingroup$ Good description and examples. In my discussions with the FAA, they've very seldom used the term fail-soft. They typically refer to the key behavior of a fail-soft system which they term "graceful degradation" to the fail-safe state. $\endgroup$
    – Gerry
    Sep 18, 2017 at 16:23
    $\begingroup$ A loss of all hydraulics is not a common failure mode. It also is definitely not fail-safe. Because there is no cable connection on A320. The “mechanical” connection means a hydraulic one. If you lose all hydraulics, you are in serious trouble. $\endgroup$
    Sep 19, 2017 at 8:57
    $\begingroup$ I strongly suspect that the behavior of a F-16 after failure of one or more flight control system(s) depends very strongly on the cause of the failure. Some of those failure causes may not apply to typical airliner operation. $\endgroup$
    – user
    Sep 19, 2017 at 11:40
    $\begingroup$ Slightly OT I find it odd that the F-16 has 4 independent systems. What if 2 are in agreement on one value and 2 are in agreement on another value? Granted, that's unlikely but not impossible - if weather is coming in from the right side, I could see the possibility of pitot tubes on that side freezing over while those on the left side remain clear. /OT thoughts $\endgroup$
    – FreeMan
    Sep 19, 2017 at 11:48
    $\begingroup$ @FreeMan: The F-16 has four so it can still hold a majority vote if one fails. This is actually triple-redundant (one system, three more for redundancy) but colloquially (and wrongly) called quadruple-redundant. $\endgroup$ Sep 20, 2017 at 16:15
