I am curious if a rotorcraft could be suspended from rotorhead for an extended period of time.
I am curious about R22 and R44. I believe I have seen them in the shop lifted up from the 2 holes in the rotor head.
I am also curious if all helicopters have mount/lift points in the rotor head like an MD500C. Would you be able to do the same?
Or are you better lifting from the skids for a longer term lifting?
  • 17
    $\begingroup$ I‘m pretty sure all helicopters are suspended from their rotors when flying. Seems to work for most of them. $\endgroup$
    – JustSid
    Sep 17, 2017 at 20:42
    $\begingroup$ @JustSid Bearings can be rated for lower static loads than dynamic loads - when flying, your rotor is definitely not static. $\endgroup$
    – Sanchises
    Sep 17, 2017 at 20:48
  • 7
    $\begingroup$ And if you're looking for the lift points, best to consult the specific aircraft type maintenance manual to find out precisely what to do and how to do it. $\endgroup$ Sep 17, 2017 at 20:48
  • $\begingroup$ I was just in the R44 and can confirm, it is lifted via the rotors $\endgroup$
    – Noah Wood
    Jan 31, 2018 at 7:36
Yes, but you better know what the heck you are doing. :) Whether an individual helicopter can be lifted this way is a different question. You'd have to look at the maintenance manual for the individual aircraft for the answer.
CH-47 being lifted onto a ship by crane.
    $\begingroup$ Note the crossbar: The side loads of a crossbar-less hoist would definitely crush the rotor mounts. $\endgroup$ Sep 29, 2017 at 23:48
  • $\begingroup$ @PeterKämpf Absolutely. Hence my "...you better know what the heck you are doing." comment! LOL! :) $\endgroup$ Sep 30, 2017 at 9:10
    $\begingroup$ That comment applies to just about everywhere. And is often enough neglected … $\endgroup$ Sep 30, 2017 at 9:30
  • $\begingroup$ ...and usually preceded by "Watch this!" in any number of languages. :) $\endgroup$ Oct 1, 2017 at 10:24
