Traditional pontoons are big and cause a lot of drag. It would be nice to retract them like normal landing gear but they are just too big.
Has there ever been a seaplane with inflatable airbags instead? They way I imagine it is a lot like normal landing gear, with lowering struts from the wings or belly. But instead of wheels, it has a wound-up airbag that's unrolled and inflated.
I think this would save a lot of drag and weight, and I'm a little surprised that this apparently doesn't exist over the 114 years or so of airplane history. Is there something unfeasible about this concept? I suppose getting propeller clearance over the water is the biggest concern, but I would think slightly long legs on the landing gear would be sufficient and well worth it to save all that weight and drag from those big pontoons.
Edit: This is for the really small planes.
5 Answers 5
11
I would think the stresses would be fairly high and I dont know of any off the bat but there have been helicopters outfitted with them.
(source)
On the drag front, this is only really a problem for smaller sea planes (C172, Caravan etc.). On the large side of things when you want to reduce drag a belly land design is used like in a Grumman G-21 or even as far as the worlds largest airplane the Hughes H-4 Hercules.
  • $\begingroup$ Yeah a belly-lander works for bigger planes but the thing I was envisioning was a small, single-engine piston prop plane. A belly-lander probably won't have enough clearance for its propeller. $\endgroup$
    – DrZ214
    Sep 18, 2017 at 2:53
  • $\begingroup$ Is that a ... duck-style walking helicopter? $\endgroup$
    – yo'
    Sep 18, 2017 at 12:57
    $\begingroup$ @DrZ214 there have been some single engine belly landers over the years like the SeaBee $\endgroup$
    – Dave
    Sep 18, 2017 at 13:25
The Goodyear Inflatoplane was used with a hydroskid so technically one can say that there has been at least one plane with inflatable floats. There also several ultralights that use soft floats, too.
  • 9
    $\begingroup$ Life just got a bit better knowing that inflatable planes exist and could fly for hundreds of miles. $\endgroup$
    – Sanchises
    Sep 18, 2017 at 6:40
  • $\begingroup$ Sounds like the Inflatoplane was a reasonable option for recovering a downed pilot, but useless for other troops who didn't have flying skills. $\endgroup$
    – FreeMan
    Sep 18, 2017 at 14:47
    $\begingroup$ "ATC, we've lost cabin pressurization. Request emergency descent to FL 0 at 9.8 m/s^2" $\endgroup$
    – 0xDBFB7
    Dec 23, 2018 at 18:18
There was an attempt made during the 1950s to build a sea-plane fighter jet with retractable water skis (the Convair F2Y Sea Dart). The basis for the idea was that supersonic fighters were bigger and heavier than all previous fighters, and the US Navy was worried that the carriers would be too short for safe takeoffs and landings.
With a seaplane there was no such worry; the aircraft could simply be lowered into the sea, turn into the wind and take off, and be hoisted back onto the carrier after it had landed.
  • $\begingroup$ Apparently, the F2Y is the only seaplane ever to have gone supersonic. $\endgroup$
    – Vikki
    May 25, 2018 at 3:08
The stresses on an inflatable float at take-off and landing would probably have been too high for the materials of the 1920s and 1930s, when seaplanes and flying boats were economically and militarily important. Another approach was invented by the Blackburn Aircraft Company in the UK: a retractable float.
Their B-20 experimental flying boat avoided having the deep hull that would have been necessary for propeller clearance by being able to lower its whole underside a few feet. This did actually work, and the aircraft's crash was due to an unrelated flutter problem. enter image description here
Bell did some experiments with a hovercraft setup on a Lake LA-4. If you do a Google image search for "Bell Aerosystems air cushion undercarriage", you'll see pictures of it, as well as a DHC Buffalo and a Soviet attempt. https://goo.gl/images/uVUFfA
