For thrust reversal after landing, a turboprop engine reverses blade pitch and blows air forward. But the engine itself requires air flow for the turbine.
How can a turboprop engine keep running when the prop blows air away from it?
Sign up to join this communityFor thrust reversal after landing, a turboprop engine reverses blade pitch and blows air forward. But the engine itself requires air flow for the turbine.
The prop is not blowing air away from the intake, atleast in that region. In modern propellers, the twist of the blades is such that the blade angle is smaller at the tip compared to the root.
Airfoil section in propeller blade; image from FAA Pilot's Handbook
Now, if reverse thrust is applied, the outer regions of the propeller is in the negative angle of attack, producing reverse thrust. However, the case is different in the root region, which won't have a negative angle, thus not blowing air 'away'. The net result is that the compressor can quite easily handle the reverse thrust condition.
Propeller angles in various flight regimes; image from pilotsofamerica.com
Another thing is that the reverse thrust is quite small compared to that of the forward flight and the speed is also quite small. modern compressors don't have much problem in this regard.
For comparison, consider the turboshaft engines in the helicopters in rearward flight- they can handle a much greater range of speeds in that condition. As an extreme case, consider the Russian aircraft doing tailslide- even the turbofan engines cope up with that, albeit in a much limited manner.
