If N1 idle is 30%, will flying idle at very high speeds force the fan to go higher than 30%? (for example idle while descending fast)
And if no, why not?
And if no, why not?
Yes, N1 should increase as the plane reaches higher speeds. This means that the blade speed will increase, therefore, increasing N1. Now because the engine setting is constant (throttle), this means that only a slight increase in the amount of thrust will happen.
