Generally, VHF frequency range is 30~300MHz and UHF is 300~3,000MHz. (according to Wikipedia). However, in ATC, VHF frequency range is 117.975-137MHz and UHF is 225MHz-400MHz.
Why is there a difference? And what are the reasons for these differences?
    $\begingroup$ It's not clear what you mean by "grounds". Do you mean why those particular frequencies, why the military wants its traffic on a separate band than civilian, or what? $\endgroup$
    – jamesqf
    Sep 2, 2017 at 5:15
    $\begingroup$ It is unclear if you ask "why do definition varies between physicists and technical operations?" or something else. $\endgroup$
    – Manu H
    Sep 2, 2017 at 14:01
17
Short answer
The reason for a difference in ranges is historical. The figures from Wikipedia are the recommended ones (by ITU, the reference in radio spectrum matters), however the abbreviations VHF/UHF are also used in related contexts, often in an attempt to discriminate similar uses when being short of other means. In the current case, FAA likely wanted to give different names to different ranges:
118-137.0 MHz: VHF Air/Ground Communications
225-328.6 MHz: UHF Air/Ground Communications
This kind of approximation has actually no practical consequences, except adding confusion to a so much misunderstood field.
Classification of waves according to their frequency is just to determine ranges where waves behave similarly, e.g HF are known to be well reflected by ionosphere, while VHF are less sensitive to such reflection and propagate more along direct light of sight. However this is a progressive and slow change, crossing the border between HF and VHF is like crossing the equator: It has no particular effect (though for the latter, there are lots of good 'proofs' I'm wrong)
There are many examples of radio concepts used approximately, e.g. when we're talking about the 'FM band' to refer to the frequency range used to broadcast using 'wideband FM' (WBFM) modulation required to transmit the large bandwidth of a high quality stereo signal; this range has no particular properties and is not a 'band' and is indeed not technically more appropriate for using WBFM, except regulation forbid other uses.
Close frequencies behaves identically
While there are significant changes between 50 and 600MHz, there is none between 100MHz and 130, 220MHz and 300, or 320MHz and 340.
The only exceptions are not relevant to aviation. Sudden changes in behavior of waves with close frequencies are possible due to absorption of narrow isolated ranges by atmospheric components, e.g. water molecules are small antennas absorbing signals at their resonance frequencies, but resonance occurs at 22 GHz.
Significant differences in radio waves relate to frequencies which are remote
The most significant change in propagation is how much waves can be reflected by the atmosphere and the ground. When such reflections are possible, the communication range is spectacularly increased, as waves can be guided like in an optical fiber towards the receiver area. But again there is no big difference between frequencies belonging to adjacent classes, but near their common border. Broad modes of propagation:
  • Below 3MHz (a wavelength of 100m), transmission takes advantage of the ground wave (ground currents) to travel on long distances.
  • Between 3Mhz (100m) and 100MHz (3m), long distance links use the sky wave (reflection on ionosphere, during specific periods of time and according to solar activity, for more on that, see What is the night effect?). Current propagation predictions with close frequencies tending to propagate identically (thanks and credits: Paul L. Herrman et al $\tiny 73$):
  • Above 100MHz (3m), transmission strictly requires a line of sight and no obstacle in the 1st Fresnel ellipsoid which volume is dependent on the distance between stations, else significant losses occur.
These three first classes are perhaps the most fundamental, then additional divisions have been created above 100MHz (which at the time was already in the "very" high frequency class), because materials can behave significantly differently, e.g. at 150MHz, the only acceptable type of transmission line is coaxial, non-coaxial lines have too much losses, at 15GHz metallic lines are not usable anymore, due to skin effect, dielectric behavior, thermal noise, to name only the first reasons, hollow waveguides are used.
Why are there different classifications for radio waves?
Different segmentations of the whole electromagnetic spectrum have been proposed by different organizations, to focus on the differences that are important for them. These classifications have not to be particularly strict for the reasons explained above, and the limits in publications have varied.
The one Wikipedia is referring to uses segment frequency limits in "3" (3, 30, 300), these limits when expressed in wave lengths become 10m (30MHz), 1m (300MHz), 10 cm (3GHz), etc ($\small \lambda = c / f$).
Source
These limits are the ones recommended by the ITU in ITU-R V.431, and they are the most commonly used. Not that there are bands without names (but all bands have a specific number).
Sometimes it is useful, or necessary to subdivide the spectrum into smaller chunks. For example TV broadcasting has operated different ranges of frequency spanning HF/VHF/UHF, transmitting at high power. However in the beginning it was not possible to build reliable powerful amplifiers at economical price, except at lower frequencies, so TV started in HF/VHF. As technology improved and higher frequency ranges became workable for amplifiers, new names were used to refer to frequency and associated electronics, exactly like cellular infrastructures and phones are known as 3G, 4G, 5G. We have all seen those names, when tuning the channels: Band I (broadly the "FM broadcast" band), II, III (174-230MHz), IV, V (582-960MHz).
Space communication engineers have their own classification of the SHF and upper bands as letters (L, S, C, Ku, Ka...). This split is well suited to describe the communication capabilities.
  • For example the US Orbiter communicated with a built-in S band antenna (2GHz), but could deploy a Ku band antenna (16GHz) from the payload bay when in orbit, to increase the transmission rate, e.g. for video streaming.
Radar people have also invented their own bands, for their specific use of the radio spectrum:
Source
And for many persons, waves are also known as short waves and long waves, categories which have been seen during years on radio receivers:
FM/SW/MW/LW on a legacy radio receiver
FM/SW/MW/LW on a legacy Grundig Satellit receiver
Likewise many engineers also use the term 'decametric' ('deca') to refer to MF/HF, or 'centimetric' and 'millimetric' for waves in the hyperfrequency domain. Those names have also been recognized by the ITU, though the mapping is somehow approximate.
Indeed aviation has had a need to create frequency segments.
VHF/UHF in aviation
"Aviation bands" include:
 - 108 - 112  MHz NAVAID (VOR, ILS Localizer)
 - 112 - 118  MHz NAVAID (VOR, LASS and SCAT-I))
 - 118 - 137   MHz VHF Air/Ground Communications
 - 62 -  174   MHz Fixed, mobile Communications
 - 225.0 - 328.6 MHz UHF Air/Ground Communications
 - 328.6 - 335.4 MHz NAVAID (ILS Glide Slope)
 - 335.4 - 399.9 MHz UHF Air/Ground Communications
 - 406.0 - 406.1 MHz Satellite Emergency Position Indicating Radio Bcn
Source: FAA order 6050.32 (page 29).
FAA has chosen to see the 225.0 - 328.6 MHz segment as being UHF, even if it starts before 300 MHz. This has no technical impact or implication, wave at 225MHz behave like these at 300, the actual difference from a technology standpoint is more between 150 and 350MHz.
Frequency allocation
In the US, the radio spectrum is allocated to users and final use according to this map (year 2016):
Source
In Europe, spectrum allocation is under ECC responsibility. Current status can be found in "ERC Report 25", aka the European Common Allocation (ECA) Table.
