Attached is a screenshot from a flightplan created with Jetplan. Can someone help with decoding the format? What do the abbreviations mean in the table header? Jeppesen FlightPlan page 2
I understand the following:
FLT = Flight Level *100
T = ?
WIND = Wind speed & direction
TAS = True Air Speed
S = ?
GRS = ?
MCS = ?
DST = Distance to next waypoint
DSTR = Distance remaining
ETE = estimated time en-route
ETR = estimated time remaining
FU = fuel used?
FR = fuel remaining?
FF/E = ?
GRS = Groundspeed
MCS = Magnetic Course
FU = Fuel burned that leg (100s)
FR = Fuel Remaining
T = OAT in degrees C, apparently without the sign.
S = Shear value (measure of turbulence) forecast
FF/E = Fuel Flow per Engine per hour
With thanks to @mins for filling in the gaps!
  • $\begingroup$ I doubt T is temperature. Is too high at those altitudes, even if it was in Fahrenheit. $\endgroup$
    – Stefan
    Aug 28, 2017 at 14:11
  • $\begingroup$ @Stefan Standard temp at FL180 is -21C, so 25 as temperature without the sign might be right. This flightplan doesn't look to be in the stratosphere, just at 180. The "S" value seems to always be a 1, unless it's omitted. No guess there. $\endgroup$
    – Ralph J
    Aug 28, 2017 at 16:10
  • $\begingroup$ that makes perfect sense, thank you to both @RalphJ and @mins! $\endgroup$
    – Stefan
    Aug 29, 2017 at 7:01
