When the FAA said that pilots require 20/20 vision, does that mean that you have to achieve 20/20 vision with glasses or without glasses?
    $\begingroup$ For what level medical? $\endgroup$
    – Ron Beyer
    Aug 23, 2017 at 16:58
    $\begingroup$ Any lvl 1/2 or 3 $\endgroup$ Aug 23, 2017 at 17:15
It can be with correction. And note that for third class, distant vision only has to be correctable to 20/40. The near vision standard is 20/40 for all classes. See https://www.faa.gov/about/office_org/headquarters_offices/avs/offices/aam/ame/guide/standards/
As @Pondlife notes, the operative words here are, "with or without correction."
    $\begingroup$ So can I be a pilot if I have a power of 20/400 which can be corrected to 20/20 using glasses? $\endgroup$ Aug 23, 2017 at 19:04
    $\begingroup$ @JohnsonPaul I have around that range of vision in one eye (-5.75 correction) and had no issues getting a Class 2 medical in the UK. I realise yours is FAA centric but I find it hard to believe it'll differ much. Ironically mine corrects to 20/16 (6/5) which is better than average $\endgroup$
    – Dan
    Aug 23, 2017 at 19:11
    $\begingroup$ I'm no AME, but I don't see any reason why not. There's no uncorrected vision requirement in what I linked, anyway. $\endgroup$ Aug 23, 2017 at 19:51
    $\begingroup$ You might want to quote the most relevant words from the AME guidance: "with or without correction". $\endgroup$
    – Pondlife
    Aug 24, 2017 at 3:30
    $\begingroup$ And if you need corrective lenses, they become a restriction on your medical certificate. Mine states: Pilot must wear corrective lenses for distance vision while exercising the privileges of this certificate. Pilot must have in his possession corrective lenses for near vision when exercising the privileges of this certificate. $\endgroup$
    – Gerry
    Aug 25, 2017 at 18:23
