Small aircraft have used and still use at least for wings, and perhaps for fuselage, material like wood and canvas, as visible on the bottom side of this wing:
Robin DR400, source: aeroVFR
Which kind of fabric / which treatment are used? What are the limits:
  • Are such structure able to withstand bad weather, rain, hail...
  • Refresh periodicity
  • Maximum wing load / aircraft size
    $\begingroup$ about weather, we have a partial answer here: aviation.stackexchange.com/a/19574/1467 <An additional benefit in the war for independence of the Baltic states during 1919 was their robustness - the fast shifting front lines made solid hangars impossible, and wooden airplanes were unusable after rain, so on many days only Junkers airplanes could take to the air.> $\endgroup$
    – Federico
    Aug 17, 2017 at 14:20
  • $\begingroup$ The fabric was painted with something called "dope" that made the wings waterproof. Dope is a plasticized lacquer and you can still buy it for model building. $\endgroup$
    – zeta-band
    Aug 17, 2017 at 15:55
    $\begingroup$ @zeta-band You can still buy butyrate dope for full sized aircraft. $\endgroup$ Aug 17, 2017 at 15:57
    $\begingroup$ FAA's Aviation Maintenance Technician Handbook - Airframe has some details about the fabric coverings used in modern aircraft. $\endgroup$
    – aeroalias
    Aug 17, 2017 at 16:08
Wood and canvas are not meant to be used in humid conditions. All outer surfaces are painted, so they are water repellent and can sustain a shower, but when left to the elements, wooden aircraft deteriorate rapidly. The unprotected structure will take up water and will warp. Wet canvas is less taut, many glues lose strength when wet and plywood will come apart over time. When a wooden aircraft has suffered a shower, it should be wiped dry and stored under a roof as soon as practical.
When Junkers introduced all-metal aircraft, they were sometimes the only types to fly because bad weather had made all other types unusable. In the war for independence of the Baltic states during 1919, the rapidly moving frontline made the use of aircraft hangars impossible, and only Junkers airplanes were able to operate on rainy days.
DeHavilland designed a sleek, four-engined airliner, the DH.91 Albatross, in 1936. The last three of seven built were put out of service after a crash in Shannon in 1943. This crash had made the fact obvious that the plywood structure had deteriorated beyond repair in bad weather, despite a fabric-and-dope cover to protect it from the elements.
The good thing about wood is its long-term strength. In stark contrast to aluminium, wood shows no fatigue under stress and allows to design a life-safe structure. When stored and operated properly, a wooden aircraft will last centuries. While the fabric cover will lose strength over time and needs to be replaced maybe every 20 years, the wooden structure needs no rejuvenation.
The maximum size of wood-and-canvas aircraft was demonstrated by the Caproni Ca.60, and that of wooden aircraft by the Hughes H-4. Both were the biggest aircraft of their time (1921 / 1947) and were bigger than a Jumbo Jet if you use wing area to measure size. However, fabric cover puts a low limit on flight speed, and indirectly on wing loading. The DH.91 had only 134 kg/m² and I would be surprised if any wood-and-canvas aircraft with a wing loading above 200 kg/m² exists. Even the plywood-covered DH.98 Mosquito had only 195 kg/m².
Now to the materials: Otto Lilienthal used osier stakes which he covered with nettle cloth. As far as I know, treatment was wax (applied dissolved in a volatile solvent). Early designs used linen or cotton and dope for glueing the cloth to the structure as well as tightening the cover. Since maybe 50 years those natural fibers have been displaced by polyester cloth because it has less of a tendency to rot. Still dope is used for glueing and tightening, and a finish of synthetic resin lacquer is used as topcoat.
  • $\begingroup$ The Hughes H-4 was larger still. $\endgroup$
    – user12007
    Aug 18, 2017 at 7:47
  • $\begingroup$ @Pete: Did it had a canvas-covered wing? I changed the label slightly. $\endgroup$ Aug 18, 2017 at 10:43
  • $\begingroup$ From what I read, it was covered with birch laminate. Not much metal could be used due to wartime restrictions. So, it wasn't canvas, but the use of wood laminate is probably still covered under this question... $\endgroup$
    – user12007
    Aug 18, 2017 at 10:51
  • $\begingroup$ One additional point: because aircraft are weight-limited in design, reliability cannot be designed in by oversizing all the critical components. Instead, reliability is inspected in by requiring teardowns at fixed intervals so that material failures and fatigue cracks can be detected before catastrophic failure. This is a perfectly valid engineering approach in a weight-constrained design space. $\endgroup$ Jan 13, 2020 at 3:39
