I've noticed that the flight BR087 from TPE to CDG doesn't follow an orthodrome.
Instead, it seems to take great pains to avoid the Chinese airspace entirely.
BR087 flight path
Why? EVA Air has other flights connecting Taiwan to China.
For instance, a similar flight KLM808 follows the orthodrome more closely :
EVA Air is Taiwanese. Taiwan and People's Republic of China are not on the best of terms (publicly).
The relations between China and Taiwan have been characterized by limited contact, tensions, and instability, due to the fact that the Civil War merely stopped without formal signing of any peace treaty and the two sides are technically still in a state of war.
The details of the bilateral Air Service Agreements (ASA's) are not public though. Treating airlines differently is supported by a discussion on airliners.net.
EVA Air does land in Mainland China, but that's only recently. That's because ASA's are not black and white. (Both economies have been on good terms lately.) An example of the limited liberalization:
The first direct commercial flights from China (from Guangzhou) to Taiwan since 1949 arrived in Taipei on January 29, 2005.
About 70% of the Chinese airspace is military controlled, i.e., the military may choose to allow KLM, but not EVA Air.
Aviation experts agree that one of the main problems in China is the fact the country’s airspace is largely controlled by the military, leaving little room for civilian aircraft even as the domestic airline industry booms. According to the state-run China Daily newspaper, less than 30% of China’s airspace can be used by commercial airlines, compared to about 80% of the airspace in the United States (BBC, April 2016).
As DeltaLima mentioned, KLM operates a subsidiary on those routes, KLM Asia:
A wholly KLM-owned subsidiary registered in Taiwan was established in 1995 to operate flights to Taipei without compromising the traffic rights held by KLM for destinations in the People's Republic of China.
Here is another example a couple of hours apart (do note China Airlines is Taiwanese).
(flightaware.com)
  • $\begingroup$ I also initially assumed the reasons set forth in this answer might be the cause. However, this supposed reason no longer seems to be a factor. EVA apparently has direct flights between Taiwan and mainland China. $\endgroup$ – J Walters Aug 14 '17 at 21:57
  • $\begingroup$ Also has to avoid north korean airspace as well $\endgroup$ – chickenricekid Aug 14 '17 at 22:29
    $\begingroup$ Also note that KLM has a special subsidiary company called KLM Asia which is registered in Taiwan. It has its own fleet (without the KLM crown and without Dutch national symbols) and performs the flights between Amsterdam and Taipei on behalf of KLM. $\endgroup$ – DeltaLima Aug 15 '17 at 8:00
  • $\begingroup$ Even for carriers from other countries , all flight to Taiwan without special permission have to pass through HongKong airspace before enter/after exit Mainland China airspace. Here are some example : TK24 (IST-TPE) , EK366 (DXB-TPE) ,VJ940 (HAN-TPE) $\endgroup$ – Him Aug 15 '17 at 17:18
  • $\begingroup$ I don't suppose PRC and ROC have too many formal agreements since both sides consider themselves the same country. That's gotta be a tough spot for the airlines in Taiwan $\endgroup$ – TomMcW Aug 15 '17 at 17:54
