21
(Source)
Why did some Sud Aviation Caravelles have a very long dorsal fin stretching half the fuselage?
Initially I thought it's to keep the fin low to fit in existing hangars as a selling point, but the variant shown above (10B3 Super B) can also be found without this fin:
(Source)
There are two competing theories on airliners.net forums. One of them says it's fuselage strengthening for over-water flights in case of ditching. The other is a housing for an optional HF antenna. As far as I know, an old HF antenna was a stretched wire.
I checked the English, French, and Swedish Wikipedia articles, only the Swedish mentions it:
The aircraft was also equipped with a long dorsal fin (Google translate).
A Flight issue from 1956 does not show the fin in their cutaway (the article also does not mention it).
    $\begingroup$ Fuselage strengthening for ditching, yet the reinforcement stops at mid fuselage? One would expect a bit more height if this was a structural member. $\endgroup$
    – Koyovis
    Aug 14, 2017 at 8:19
    $\begingroup$ It's for ditching - when the sharks come they think the plane is a bigger shark and stay away :P $\endgroup$
    – TomMcW
    Aug 15, 2017 at 17:23
    $\begingroup$ It's not a fin, but a fairing. $\endgroup$ Jan 4, 2019 at 10:00
17
The dorsal ridge housed avionics and HF antennas. From this document:
The most noticeable difference are the larger cockpit windows and the removal of the dorsal fin (the long fin on top of the fuselage), that housed avionics. The 6R's not built for United did have the dorsal fin, though.
This is a non metallic radome. It protects the antenna from aerodynamic effects, and from water and ice which damage antenna electromagnetic characteristics. Closer view:
Source
The HF antenna was required when using long range HF navigation (Loran) and HF communications, typically over oceans and large non populated areas.
These features were not useful when flying over populated land, where VHF aids and VHF communication were possible.
There is a list of C/N without the dorsal fin in this forum. When the antenna is not under a radome, it looks like this:
Source (simulator)
See also: What is this wire going from mid-fuselage to the tail on this 737?
Progress in antenna design and receivers with (hugely) increased sensibility allow for smaller antennas, that can afford to be vertical with some signal losses. Today HF antennas tend to be vertical and under a radome at the leading edge of the vertical stabilizer:
Source
Helicopters, civil and military still use long wire antennas as antenna rails when they need HF:
Source
See also: What is this pipe on the tail of this helicopter?
  • $\begingroup$ The fifth link (to the forum post listing those Caravelles without the dorsal fin) is broken. $\endgroup$
    – Vikki
    Mar 18, 2023 at 21:09
