If an aircraft encounters a serious problem quite soon after departure that forces it to land immediately, the aircraft may be above its certified maximum landing weight. This is because there is still a lot of fuel in the tanks, which adds a lot of weight.
As @RonBeyer mentioned in a comment, landing overweight can have a number of serious consequences. When landing a heavy aircraft, stopping it on the runway already requires a lot of energy (or rather, a lot of energy needs to be converted into something else). If the aircraft is heavier than it is designed to be on landing, this may cause excessive stress on the brakes. In extreme cases, this can make the brakes catch fire. Now, open flames under an aircraft that is almost fully loaded with fuel is the recipe for disaster.
In some cases, even though the crew brakes hard on landing, the aircraft may be so heavy that stopping on the runway is impossible. A runway excursion will then follow (a situation where the aircraft leaves the runway onto the grass or similar). This is not neccesarily dangerous, but it certainly can be, depending on the surrounding terrain:
(image from http://avherald.com/h?article=46f3d531. This aircraft was not overweight, but I still think the situation shown in the picture is relevant to this question.)
Obviously, in an emergency ATC, and in turn the fire and rescue crew at the airport, need to be prepared for such events. If ATC expects an aircraft will be landing overweight, getting the crew to confirm this will allow ATC to inform the fire crew that they can expect brake fires or a potential runway excursion. It can also enable the rescue leader to position the fire vehicles at the best possible position, which would be further down the runway than normal, since the landing roll will be longer. So basically, it's a way to get information to the rescue crew so that they can prepare for what might be coming.
Depending on the type of emergency, ATC will also ask the crew about other details, in some cases also with the purpose of passing this information on to the rescue crew, since the rescue crew will normally not be in direct contact with the cockpit as long as the plane is in the air. See also this related question: Why does ATC ask emergency aircraft about fuel on board?
