What is the difference between a "nautical mile" and a "statute mile?"
And what is a "knot?"
  • $\begingroup$ I disagree, the answer to what is the measurement system used in aviation is different than the definition of the unit of measurement itself. I searched the questions and didn't find this question so I decided to contribute it. I'm asked this question all the time by laypeople so I figured it may be useful to have it on this site. $\endgroup$
    – Devil07
    Aug 5, 2017 at 20:52
    $\begingroup$ Nautical mile, statute mile, knot. You're expected to do some basic research before posting. $\endgroup$ Aug 5, 2017 at 21:36
    $\begingroup$ I did basic research, and discovered that this question was not answered on this site. Just because wikipedia has a page on the topic, doesn't mean that we are not allowed to post it here. $\endgroup$
    – Devil07
    Aug 7, 2017 at 16:12
  • $\begingroup$ Just because an answer to a question can be found on wikipedia doesn't mean that it shouldn't be asked or answered on this site. Any question that is useful and results in increased traffic and visits improves our site. $\endgroup$
    – Devil07
    Aug 8, 2017 at 13:49
13
According to the Encyclopedia Britannica a nautical mile used to be based on the curvature of the earth and was approximately equal to one minute (arc segment) of latitude along a meridian (longitudinal line running from north to south). The British nautical mile was set to 6,080 feet while the US nautical mile was set to 6080.20 feet. However, in 1929 the nautical mile was redefined to exactly 1.852 km (approximately 6076.11549 feet) at an international conference held in Monaco, although the US didn't make the conversion until 1954.
1 nautical mile = 1.1508 statute miles or 1.852 km.
A "knot" (speed measurement, not the kind you tie in your shoe laces) is equal to one nautical mile per hour.
1 knot = 1.15 miles per hour.
    $\begingroup$ In the interests of fairness, the term 'knots' does have its origin in real knots - See knots - the speed in knots is calculated by how many spaced knots (one every 8 fathoms) passes between a sailor's fingers in 30 seconds. $\endgroup$
    – user12007
    Aug 8, 2017 at 13:53
    $\begingroup$ @Pete that is cool. I wonder if there is a youtube video of someone demonstrating that old world method of measuring knots. $\endgroup$
    – Devil07
    Aug 8, 2017 at 14:19
    $\begingroup$ There's a YouTube for everything - logs and knots $\endgroup$
    – user12007
    Aug 8, 2017 at 14:53
    $\begingroup$ There's a lot of pirate movies (Pirates of the Caribbean) en tv series (Black Sails) where you can see this method used on ships. In aviation it seems to be less practical. $\endgroup$ Aug 8, 2017 at 18:04
There are basically two different categories: nautical units and statute units. A few times early on in my aviation career I mixed the two (especially easy if you fly in a plane that uses mph but you measure nautical miles on your sectional) and it will yield inaccurate numbers, which can be pretty dangerous, depending on the calculation you are doing. These are the three main kinematic units that relate to motion of each category and values you can use for conversions:
Category: nautical/statute; (conversion values)
Speed: knots/mph; 1/1.15
Time: hours/hours; 1/1
Distance: nautical miles/statute miles; 1/1.15
These all follow the equation distance = speed * time (as long as you do not mix and match the category (nautical units with statute units or vice versa).
Historically speaking, the nautical units were used by sailors because it was just more practical -- one nautical mile was originally defined as one minute of latitude (lines of latitude are the ones that slice the earth horizontally -- think "flatitude"), a distance which is relatively constant (although not totally so due to earth's ellipsoid shape, but much more so than minutes of longitude which vary greatly). This was more convenient for sailors to use than statute miles because latitude (as well as longitude) was frequently used to define position so it was easier to use for dead reckoning and navigation. Lines of latitude one degree apart are about 69 statute miles apart on the surface of the earth (varying slightly depending on your location on the surface of the earth), so one minute of latitude (1/60th of a degree of latitude), is about 1.15 statute miles apart on the surface of the earth (69 statute miles/60, because a minute is 1/60th of a degree). Since a nautical mile is defined as the distance of 1 minute of latitude, it turns out that 1 nautical mile is equal to 1.15 statute miles. The actual value now is set at about 1.15078 statute miles because the nautical mile was redefined to be exactly 1852 meters (now internationally accepted). Etymologically, the term derives from sailors counting the number of knots in the rope that unspooled from the reel of a chip log (basically a spool of rope) in a specific time. Aviation follows many naval conventions, nautical units included.
When you think of miles in normal life (20 mile drive, a mile run, etc.) those are all statute miles. Usually in aviation as well as in naval applications the units belong to the nautical category (20 nautical mile flight, 120 ktas (knots true airspeed)). Recently, however, some plane manufacturers have made a move towards using statute units in their manuals/avionics so keep an eye out for units, especially on more modern planes. As far as the aviation systems (what category weather reports use and what controllers use), everything is in the nautical category except for measuring visibility (you would hear wind readings at 10 knots from 160 degrees for example but a visibility report at more than 10 statute miles for example).
A similar important distinction (not related to statute vs nautical) is that when you READ angles (degrees on a winds aloft forecast or a METAR) the degrees are usually with reference to TRUE north (for flight planning purposes). When you HEAR angles (ATIS report, controller wind report) the degrees are usually with reference to MAGNETIC north. Anyway back to nautical/statute.
If your plane does use statute units there is most likely a statute mile side of your plotter (so you can measure statute miles on your sectional as well as nautical miles) -- use this instead of trying to convert the units; it will save you time and mistakes. Also most airspeed indicators can read both knots and mph, although the outside ring is the one belonging to the category that is most likely dominant in the manual (in values for cruise speeds, etc) -- in this case mph.
I hope this helped -- fly safe.
    $\begingroup$ I'm confused by this statement One degree of latitude is about 69 statute miles (varying slightly depending on your location on the surface of the earth), so one degree of latitude (a nautical mile) is about 1.15 statute miles (69 miles/60 minutes; there are 60 minutes in a degree). You seem to be defining a degree of latitude twice as two different values. Is this a typo or am I just not comprehending? $\endgroup$ Aug 9, 2017 at 1:19
    $\begingroup$ To clarify -- minutes are just a smaller measurement of angle than degrees -- for instance there are 60 minutes in 1 degree just as there are 100 centimeters in a meter. Miles are not a measurement of angle, they are a measurement of distance. When I say 1 degree is about 1.15 statute miles I mean two adjacent lines of latitude (1 degree apart) are separated by a distance of about 69 miles on the surface of the earth (a mathematical way to describe this is "arclength" rather than angle)... $\endgroup$ Aug 9, 2017 at 2:34
    $\begingroup$ So shouldn't the sentence read "One degree of latitude is about 69 statute miles (varying slightly depending on your location on the surface of the earth), so one minute of latitude (a nautical mile) is about 1.15 statute miles (69 miles/60 minutes; there are 60 minutes in a degree)" $\endgroup$ Aug 9, 2017 at 2:48
    $\begingroup$ Ah yes now I see my mistake -- I meant to say one minute -- thank you for catching that... I guess I just overexplained it for nothing. $\endgroup$ Aug 9, 2017 at 2:52
    $\begingroup$ No worries, very informative answer! $\endgroup$ Aug 9, 2017 at 2:55
