This question has several great answers showing that it's perfectly possible for a helicopter to fly with its blades underneath the rest of the aircraft.
There are some obvious issues with having a helicopter's blades at the bottom, to do with proximity to the ground and being in the way when someone wants to get in or out of the helicopter. Is the answer that simple, or are there other reasons related to flight dynamics, manufacture, or something else?
Yes the answer is that simple, that mincer needs to be out of the way so it doesn't chop peoples' head or feet off, or slashes into a bit of concrete and shatters into 100 pieces scattered around like bullets. That is the main reason why the light 2-seater R22 has the rotor mounted on a pylon, at 2.7 m it is out of the way of most people.
enter image description hereImage source
Flight dynamics wise, a rotor underneath the helicopter has speed stability in the hover, which makes the helicopter easier to control. The rotor acting as a pusher makes it more efficient; being closer to the ground means more lift in ground effect and softer take-off and landing. Manufacturing:
  • The rotorhead of an underslung rotor would look pretty similar to the top mounted one, a hinge offset head would line up the fuselage with the rotor disk, top or bottom.
  • The rotor would have to be situated away from the fuselage to allow for the upwards coning and tilting under flight conditions - for instance mounted on an upside down pylon quite similar to the R22.
So all in all an underslung rotor poses no particularly vexing engineering problems and provides improved stability and better performance - it would just be an immensely impractical machine.
    $\begingroup$ It does have one engineering problem I can think of - how would the landing gear pass through the rotor? Unless it had massive insect-like legs that reached past the rotor tips. $\endgroup$ – Skyler Sep 21 '17 at 18:13
    $\begingroup$ @Skyler well I was going to lump that under impracticality. They could stick 2 wheels out of the rotor mast, and a tail wheel from the tail rotor. $\endgroup$ – Koyovis Sep 21 '17 at 18:17
There were some experimental "helicopters' with rotors on bottom:
A current design, also capable of transitioning to horizontal mode http://aliptera.com/#ADR-1
    $\begingroup$ That's not a helicopter. (But it's a cool machine). $\endgroup$ – KorvinStarmast Aug 9 '17 at 2:05
