Departure way points for Runway 4R at Logan Airport in Boston Massachusetts. Can anyone send me a map depicting where the first 2 way-points are for 4R Departures?
$\begingroup$ This is going to be dependent upon the specific departure chosen or assigned by ATC. Which departure are you flying? $\endgroup$– Carlo FelicioneJul 10, 2017 at 15:57
2$\begingroup$ @CarloFelicione All departures from 4R have NHANT and HURBE as the first two waypoints. $\endgroup$– SMS von der TannJul 10, 2017 at 16:33
1 Answer
Checking the IFR departure plates for KBOS, the first two waypoints for all departures from Runway 4R are NHANT and HURBE. You can see where they are on the Google map below.
BLZZR THREE departure plate for reference.
1$\begingroup$
<— This is not strictly true. This does appear to be true for all RNAV based departures with departures specifically listed for 4R (those with waypoints) but is not true for the Logan Two which calls for headings to DME distance. $\endgroup$– J WOct 25, 2017 at 0:24
