In a glider review for the Schempp-Hirth Discus, I encountered the following paragraph:
The Discus 2 airfoil is thin (about 14.5 percent), incorporating studies by K.H. Horstmann and Dr. Wuerz (wing) and Luc Boermans (tail).
After researching this a bit, I've been unable to find an explanation for what "14.5 percent" was referring to.
I thought perhaps that it is the ratio (14.5/100) of the thickness of the wing to the width of the wing, but that is really just an educated guess.
The Wikipedia page on airfoils has a section entitled Thin airfoil theory, with two bullets which also might qualify:
(1) on a symmetric airfoil, the center of pressure and aerodynamic center lies exactly one quarter of the chord behind the leading edge (2) on a cambered airfoil, the aerodynamic center lies exactly one quarter of the chord behind the leading edge
Is this "one quarter" the ratio that is mentioned in the article?
I did see this post, but had trouble seeing how the 90% and 99% numbers mentioned in the answer are related.
    $\begingroup$ 14.5% is a relative thickness (thickness divided by chord) $\endgroup$
    – Gypaets
    Jul 5, 2017 at 22:22
  • $\begingroup$ You could call it the 'cross-sectional aspect ratio'. $\endgroup$
    – amI
    Jul 5, 2017 at 22:51
14.5% given in the article is the (maximum) thickness to chord ratio, expressed in percentage. It is usually used to explain how thin (or thick) the airfoil is. Note that this is a characteristic of the airfoil.
From the NASA page Wing geometry definitions:
Wing Geometry
Airfoil thickness to chord ratio, image from NASA page Wing geometry definitions
... The straight line drawn from the leading to trailing edges of the airfoil is called the chord line. ... The maximum distance between the two lines is called the camber, which is a measure of the curvature of the airfoil (high camber means high curvature).
The maximum distance between the upper and lower surfaces is called the thickness. Often you will see these values divided by the chord length to produce a non-dimensional or "percent" type of number.
  • $\begingroup$ Well, at least the answer was on the page "intended for college, high school, or middle school students" :-). Seriously, the linked page does a great job of putting this stuff into layman's language. Thanks for the answer! $\endgroup$ Jul 6, 2017 at 20:23
From this link:
The red line is the cross section of a wing. The main dimension in the profile is the black line in the middle at a slight angle: the wing chord. All dimensions in this NACA profile are defined relative to the wing chord:
  • 2% camber (the slight upward bend in the middle line)
  • 30% max camber position: top of the bend occurs at 40% chord
  • 12% thickness: maximum thickness of the profile is 12% chord.
The profile is defined this way because for instance with a tapered wing planform, we can still define the profile at any point at the wing if defined relative to chord.
  • $\begingroup$ Clarification? Is it the black line that is the chord? The black line looks to me like it is part of the graph and doesn't look like it curves. Wouldn't it be the gray line? $\endgroup$ Jul 6, 2017 at 16:18
    $\begingroup$ @bclarkreston, yes, the black line is the chord. It is also the $x$ axis, because the profile is normalized to have the leading edge at origin and the trailing edge at $(1, 0)$. The gray line is the camber line. $\endgroup$
    Jul 6, 2017 at 18:58
  • $\begingroup$ Got it...that made sense after reading the NASA page @aeroalias posted in his answer. $\endgroup$ Jul 6, 2017 at 20:19
