A well-known "elliptical" wing:
One of the 50 Spitfire still flying in the World. Source
My questions
- What is elliptical in the elliptical wing?
- What is regularly distributed: lift? drag? something else?
Sign up to join this communityA well-known "elliptical" wing:
My questions
It is both the planform and the circulation distribution. Note that circulation is not lift coefficient but bound vortex intensity. You can interpret it as local lift coefficient times local chord.
On the untwisted elliptical wing the local lift coefficient is constant over span, and changes in angle of attack over the linear range will change the lift coefficient equally everywhere. This, when combined with the elliptical chord distribution over span, means that the circulation distribution will stay elliptical over the linear angle of attack range. This is the special characteristic of an elliptical wing: While any wing can have an elliptical circulation distribution at one angle of attack (given the right twist distribution), the elliptical wing will keep that elliptical circulation distribution over the whole operating range.
With an elliptic circulation distribution comes also a constant induced angle of attack and downwash angle over span. I guess this is expressed by some authors with the term "regular".
However, only the aerodynamicists will see that as an advantage. Both weight and stall characteristics of elliptical wings are less than optimum; the low induced drag coefficient is bought with higher structural mass and, consequently, lift. A more triangular circulation distribution will yield the lowest wing weight and overall drag for a given non-lifting mass (that is, all mass that is not involved in lift generation, especially the payload). Note that for such a triangular distribution drag will be highest near the center.
When people talk about elliptical lift distribution, they mean lift per span. I prefer to use the more correct term circulation, since lift is a force as in pressure times area and can only be produced by a whole wing or at least wing section, not one spanwise station.
(Edited after comments by mods. Thanks for guiding me through the process!)
The only thing that is elliptical is the planform shape of an elliptical wing.
Many people unfortunately confuse an elliptical pressure distribution with the pressure distribution over an elliptical wing. They are not equivalent.
On an untwisted elliptical wing the local lift coefficient is not constant over span, as some here and in many other places on the internet maintain.
Arguments from lifting line theory are not appropriate for discussing the behaviour of the flow near wing tips. It is unreasonable to expect lifting line theory to be valid near the wing tips because is not a consistent large aspect ratio asymptotic expansion. See: Van Dyke, "Perturbation methods in fluid mechanics", 1964.
The span loading includes a logarithmic term, hence it is not elliptical. Furthermore, it cannot induce a constant downwash, and so at the trailing edge the vortex wake does not start as a flat sheet.
The process whereby the vortex sheet rolls up is far more vigorous than if it started out as a flat sheet because the relatively weak effect of viscosity would be the main mechanism driving that rolling-up process. There is a strong upwash in the flow-field near to and around the wing tips which initiates the rolling-up process far more vigorously.
See, for example, among many other papers:
Peter F. Jordan, "Exact Solutions for Lifting Surfaces", AIAA Journal, Vol. 11, No. 8, 1973., pp. 1123-1129.
Peter F. Jordan, "On Lifting Wings with Parabolic Tips", ZAMM 54, pp. 463-477, 1974.
The beautiful shape of the Spitfire planform also made it difficult and expensive to produce. The target was an elliptical lift distribution, at the time of design regarded as resulting in the highest lift/drag ratio.
This lift distribution is obtained by shaping the wing geometry, in the case of the Spitfire by making the chord an elliptical function of wing span. The other way of achieving this is to use a combination of wing taper and wing twist: the chord reduces linearly with span, plus the wing is twisted with the wing tip having a lower angle of attack than the wing root.
This shape creates elliptical lift distribution as well, but at only one AoA of the aircraft. The elliptical wing has an elliptical planform and elliptical lift distribution throughout all aircraft AoA.
The eliptical planform wing has a constant AoA, and drag changes as a function of wing chord only. The twisted wing has a wing root with a higher AoA, and a wing tip with lower AoA than aircraft AoA: the fat bit of the wing has the higher drag, since wing drag is a function of chord and AoA. So total wing drag of the tapered wing is higher than that of the elliptical wing.
The tapered twisted wing rules though, because:
